First post, by appleiiguy
So I got a 486 PIO-2 and the manuals online dont have any settings for an AMD 5x86 P75.
Currently I have it set for 3.45V, 2x Multiplier, 33 Mhz, and set it to Enhanced AMD 486DX4 (which should set the cpu to WB cache), and I have 512KB of cache installed.
I believe It is the correct setting but since the manual doesnt have the 5x86 setting in it I was hoping someone on Vogons had done this setup before.
The attachment IMG_0269.jpg is no longer available
The attachment IMG_0268.jpg is no longer available
The attachment IMG_0267.jpg is no longer available
ftp://ftp.fic.com.tw/motherboard/manual/486/4 … 2/486-pio-2.zip <-- The Manual
Reply 1 of 4, by Living
i got the same question
Reply 2 of 4, by jesolo
What happens if you boot up the PC?
Does it POST and what does it display on the POST screen?
Reply 3 of 4, by mpe
The AMD 5x86 P75 is the same thing as Enhanced AMD 486DX4 and needs identical settings.
Or you can use settings for Intel DX4-WB (P24D) which has identical pinout.
https://stason.org/TULARC/pc/motherboards/F/F … -486-PIO-2.html
The only extra thing 133 MHz needs is the 4x multiplier which should be easy to find. If you have a multimeter it is the R17 pin (second pin in bottom right). This pin needs to be set to high to enable 4x multiplier.
Blog|NexGen 586|S4
Reply 4 of 4, by zuldan
I have this motherboard with the 5x86 P75 CPU. Does anyone have a picture of where this multiplier jumper is so I can set the multiplier from 3x to 4x.
I’ve used a multimeter with pin (R17) on the CPU socket but can’t trace it to any jumpers.
Edit: figured it out. Will post how it’s done in the morning.
