Peixoto's patches for a few old games
Reply 620 of 896, by TheTombRaider
Guizin239 wrote:
TheTombRaider wrote:
Guizin239 wrote:
For some weird reason when I click on the Help.exe it opens a window and then closes 😒
Your virus protector probably closed it because it detected it as a virus. Don't worry it is a false positive. So make sure you add an exception in your real time scanner settings so that it doesn't detect it again. The way the program was compiled is setting off false flags in the real time scanning of whatever virus scanner you are using. Virus scanners can be a pain sometimes, especially if you use Mcafee.
I figured it could be something like this, so I disabled windows defender, and i still could not open it
Do you have any other virus protectors that may be interfering with the Help.exe?
"A famous explorer once said, that the extraordinary is in what we do, not who we are. I’d finally set out to make my mark; to find adventure. But instead adventure found me. Everything lost is meant to be found."
--Lara Croft
Reply 621 of 896, by Guizin239
I don't. However, I tried going into safe mode and it worked alright
I still have no idea what could be causing this conflict
Reply 622 of 896, by cloudhaacker
Guizin239, not saying this is the problem, but I had issues with my Final Fantasy games a few months ago and the culprit was Windows Data Execution Prevention. Try either adding an exception to it for Help.exe or try disabling DEP and see if that helps.
Reply 623 of 896, by ZellSF
Don't tell people to add exceptions to DEP. Because of confusing wording, people tend to actually enable it to add an exception (which is of course, pointless, but people aren't that good with logic and reading). The DEP settings should look like this, which they do by default.
The attachment dep.png is no longer available
Also don't tell people to disable DEP because then they might figure out how to disable it entirely. Just tell people to set DEP settings to the default and make it very clear what those defaults are (pictured above).
Reply 624 of 896, by Aluminumhaste
Thank you for making these patches!
I'm trying to get Outwars to run at 1920x1080, but it seems to only run at 640x480 maybe upscaled.
I'm also seeing some errors in the log
Peixotos's patch remote settings:
32bit: 1
<Textswap>: s=4;sz=256;path=Textures\VOKSI;n=PgUP;p=PgDn;d=home;sw=end;c=del;q=ins;
D3D: 2
D3D_Driver: nvd3dum.dll
DDRefcountfix: 1
DisableFontAA: 1
dsk: 1920x1080
error_log: C:\Games\Peixoto\Peixoto\error.log
HD: 1
HRT: 1
injector_dir: C:\Games\Peixoto\Peixoto
max_4x3_res: 1280x960
MCLP: 2
MHKS: 1
Mydocs: C:\Users\Nathan - Dekstop\Documents
os_version: 6.100000
Path: C:\Users\Nathan - Dekstop\Documents\Games\Outwars\
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1152x864 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1366x768 1600x900 1600x1024 1680x1050 1920x1080
script: scripts\Outwars.ahk
script_hwnd: 0x110602
singlecore: 1
Target: C:\Games\Outwars\outwars.exe
target_dir: C:\Games\Outwars
target_name: outwars.exe
WHKS: 1
TimeGetTime Hook 0
GetTckCount Hook 0
CreateProcessA Hook: 0
CreateProcessW Hook: 0
Desktop 1920x1080
OpenAdapter Hook 0
DDraw.dll : C:\Windows\system32\DDRAW.dll
DirectDrawCreate Hook : 0
Succeeded to create DirectDraw
Succeeded to create Direct3D
Succeeded to hook IDirectDraw::Release
Succeeded to hook IDirectDraw2::CreateSurface
Failed to hook IDirectDraw::CreateSurface - detours error 1
Succeeded to hook IDirectDraw4::CreateSurface
Succeeded to hook IDirectDrawSurface::restore
Succeeded to hook IDirect3DDevice::EndScene
Succeeded to hook IDirect3DDevice3::EndScene
Succeeded to hook IDirect3D3::CreateDevice
Succeeded to hook IDirect3D2::CreateDevice
Succeeded to hook IDirectDraw::SetDisplayMode
Succeeded to hook IDirectDraw2::SetDisplayMode
Failed to hook IDirectDraw4::SetDisplayMode - detours error 1
Succeeded to hook IDirectDraw4::EnumDisplayModes
Succeeded to hook IDirect3DViewport3::SetViewPort2
Succeeded to hook IDirect3DViewport3::GetViewPort2
Succeeded to hook IDirect3DViewport3::Clear
Succeeded to hook IDirect3DViewport3::Clear2
Succeeded to hook IDirect3DViewport::SetViewPort
Succeeded to hook IDirect3DViewport::GetViewPort
Succeeded to hook IDirectDrawSurface::flip
Succeeded to hook IDirectDrawSurface4::GetSurfaceDesc
Succeeded to hook IDirectDraw::GetDisplayMode
Failed to hook IDirectDraw4::GetDisplayMode - detours error 1
Show last 68 lines
Succeeded to hook IDirectDrawSurface::GetPixelFormat
Succeeded to hook IDirectDrawSurface::GetSurfaceDesc
Succeeded to hook IDirectDrawSurface::AddAttachedSurface
Succeeded to hook IDirectDrawSurface::GetPalette
Succeeded to hook IDirectDrawSurface::SetPalette
Succeeded to hook IDirectDrawPalette::SetEntries
Succeeded to hook IDirectDrawPalette::GetEntries
Succeeded to hook IDirectDrawSurface::QueryInterface
Succeeded to hook IDirectDrawSurface4::Lock
Succeeded to hook IDirectDrawSurface4::UnLock
Succeeded to hook IDirectDrawSurface::UnLock
Succeeded to hook IDirectDrawSurface4::Blt
Succeeded to hook IDirectDrawSurface4::Bltfast
Succeeded to hook IDirectDrawSurface4::GetDC
Succeeded to hook IDirectDrawSurface4::ReleaseDC
Succeeded to hook IDirect3DViewport3::TransformVertices
Succeeded to hook IDirect3DDevice3::DrawPrimitive
Succeeded to hook IDirect3DDevice3::DrawIndexedPrimitive
Succeeded to hook IDirect3DDevice3::DrawPrimitiveVB
Succeeded to hook IDirect3DDevice3::DrawIndexedPrimitiveVB
Succeeded to hook IDirect3DDevice2::DrawPrimitive
Succeeded to hook IDirect3DDevice2::DrawIndexedPrimitive
Succeeded to hook IDirect3DDevice::Execute
Succeeded to hook IDirectDraw::SetCooperativeLevel
Failed to hook IDirectDraw2::SetCooperativeLevel - detours error 1
Failed to hook IDirectDraw4::SetCooperativeLevel - detours error 1
StretchBlt0
BitBlt0
PatBlt 0
1 640x480-640
2 640x480-1280
3 640x480-2560
1 960x540-960
2 960x540-1920
3 960x540-3840
1 1280x720-1280
2 1280x720-2560
3 1280x720-5120
1 1440x1080-1440
2 1440x1080-2944
3 1440x1080-5760
1 1920x1080-1920
2 1920x1080-3840
3 1920x1080-7680
1 640x480-640
2 640x480-1280
3 640x480-2560
1 960x540-960
2 960x540-1920
3 960x540-3840
1 1280x720-1280
2 1280x720-2560
3 1280x720-5120
1 1440x1080-1440
2 1440x1080-2944
3 1440x1080-5760
1 1920x1080-1920
2 1920x1080-3840
3 1920x1080-7680
Resolution\Viewport:
Requested : 640 x 480
Real : 1920 x 1080
Correction : 2.250000
Viewport width correction : 240.000000
Succeeded to hook IDirectDrawSurface4::blt
Succeeded to hook IDirectDrawSurface2::blt
At first the game ran fine just running the exe, just not high res and no widescreen.
So I found your tool, and tried using it but it looks and feels the same when I run it.
Using a Gtx 1070 (latest Drivers), Ryzen 2700x
Is there any way to get this to run in widescreen native or is the in game viewport always 4:3?
Reply 625 of 896, by ZellSF
I know I've asked for a better selection of 16:9 UI sizes (resolutions to upscale from), but I didn't ask for more 4:3 sizes. Is that possible too? Maybe a common resolution like 1024x768?
Reply 626 of 896, by BlueCoral
I've tried launching Tomb Raider 2 through the patcher, and it crashes to desktop. But Tomb Raider 2 Gold works just fine for some reason?
The error I get is:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files (x86)\Core Design\Tomb Raider II\Tomb2.exe
abnormal program termination"
It's not the steam or gog version, but a CD version.
The error log is:
#args: setup
32bit: 1
D3D: 2
D3D_Driver: igdumdim32.dll
dshow: 1
dsk: 1366x768
error_log: C:\Program Files (x86)\Peixoto\error.log
GPad: A=1;B=2;X=3;Y=4;LEFT_SHOULDER=5;RIGHT_SHOULDER=6;bLeftTrigger=7;bRightTrigger=8;Start=9;Back=10;LEFT_THUMB=11;RIGHT_THUMB=12;deadzone=0.000000;
HD: 1
injector_dir: C:\Program Files (x86)\Peixoto
J2K: u=False;a=Up,Down,Left,Right,end,alt,space,ctrl,del,PgDn,shift,numpad0,esc,/,8,9,Up,Down,Left,Right;dz=0.25;
max_4x3_res: 1024x768
Mydocs: C:\Users\______\Documents
NEFS: 1
os_version: 6.300000
path: C:\Users\______\Documents\Games\Tomb Raider\TR2\
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1280x720 1280x768 1280x800 1360x768 1366x768
script: Scripts\Tomb2.ahk
script_hwnd: 0xbe0b44
singlecore: 1
svs: 1
target: C:\Program Files (x86)\Core Design\Tomb Raider II\Tomb2.exe
target_dir: C:\Program Files (x86)\Core Design\Tomb Raider II
target_name: Tomb2.exe
Textswap: path=Textures\VOKSI;s=4;sz=256;n=];p=[;d=p;sw=i;c=o;q=q;l=0;
FileHooks 0
CreateFileA_Hook Hook : 0 <- 0 means no error
Succedeed to create the DirectShow interfaces
Succeeded to hook IVideoWindow::SetWindowPosition
Succeeded to hook IMediaControl::Run
Desktop 1366x768
OpenAdapter Hook 0
DDraw.dll : C:\Windows\SYSTEM32\DDRAW.dll
Succeeded to hook IDirect3DTexture2::Release
Succeeded to hook IDirect3DTexture2::Load
Succeeded to hook IDirect3DDevice3::SetTexture
Succeeded to hook IDirect3DTexture2::GetHandle
Succeeded to hook IDirect3DDevice2::SetRenderState
Succeeded to hook IDirect3DTexture::Load
Succeeded to hook IDirect3DTexture::GetHandle
Succeeded to hook IDirect3DTexture::Release
Succeeded to hook IDirectDrawSurface4::GetAttachedSurface
Succeeded to hook IDirectDrawSurface4::EnumAttachedSurfaces
Succeeded to hook IDirectDrawSurface::GetAttachedSurface
Succeeded to hook IDirectDrawSurface::EnumAttachedSurfaces
IDirect3DDevice2::DrawPrimitive is already hooked
Method BeginScene is not hooked yet
Succeeded to hook IDirect3DDevice2::BeginScene
1 640x480-640
2 640x480-1280
3 640x480-2560
1 960x540-960
2 960x540-1920
3 960x540-3840
1 1280x720-1280
2 1280x720-2560
3 1280x720-5120
1 1024x768-1024
2 1024x768-2048
3 1024x768-4096
1 1366x768-1368
2 1366x768-2816
3 1366x768-5504
Requested : 1366 x 768
Real : 1366 x 768
Correction : 1.000000
Viewport width correction : 0.000000
Succeeded to hook IDirectDrawSurface2::blt"
Reply 627 of 896, by Peixoto
Aluminumhaste wrote:
Its running at 1440x1080 on a 1920x1080 display mode
BlueCoral wrote:
Try disabling some features to see what works or an earlier version: the current one broke a lot of thinks in anything but win 10
ZellSF wrote:
OK
Reply 628 of 896, by LukasThyWalls
Hi
I was making work Martian Gothic with the lastest patch, and i found the "Gamepad fix" doesn't work since Patch version 4. With 1-3 the gamepad works (i'm playing using version 3). Except that, everything seems fine.
Error log from lastest patch:
#script: scripts\martian.ahk
32bit: 1
<Textswap>: s=4;sz=256;path=Textures\VOKSI;n=[;p=];s=4;sw=end;c=del;q=shift;d=Home;l=0;
CompatLayer: HIGHDPIAWARE
D3D: 3
dsk: 1280x960
error_log: D:\Apps\Peixoto\06\error.log
gamma: 1
GPad: A=1;B=2;X=3;Y=4;LEFT_SHOULDER=5;RIGHT_SHOULDER=6;bLeftTrigger=7;bRightTrigger=8;Start=9;Back=10;LEFT_THUMB=11;RIGHT_THUMB=12;deadzone=0.00;
Gpadfix: 1
HD: 1
injector_dir: D:\Apps\Peixoto\06
Mydocs: D:\Apps\Documentos
Path: D:\Apps\Documentos\Games\Martian Gothic\
read: 1
resolutions_list: 640x480 720x480 720x576 800x600 1024x768 1152x864 1176x664 1280x720 1280x768 1280x800 1280x960 1280x1024 1360x768 1366x768 1600x900 1600x1024 1680x1050 1768x992 1920x1080 1440x900
script_hwnd: 0x3000e4
target: D:\Juegos\Martian Gothic\martian gothic.exe
target_dir: D:\Juegos\Martian Gothic
target_name: martian gothic.exe
Desktop 1280x960
OpenAdapter Hook 0
Show last 46 lines
Real : 1280 x 960
Correction : 2.000000
Succeeded to unhook IDirectDraw2::SetDisplayMode
Method SetDisplayMode is not hooked yet
Succeeded to hook IDirectDrawSurface::blt
Succeeded to hook IDirectDrawSurface4::lock
Succeeded to hook IDirectDrawSurface4::Unlock
Succeeded to hook IDirectDrawSurface::Unlock
Succeeded to hook IDirectDrawSurface2::lock
Succeeded to hook IDirectDrawSurface2::Unlock
ptr 53615160 use 257504 sz 17120 hwnd 257504
ptr 53602296 use 257280 sz 4252 hwnd 257280
ptr 258864 use 257280 sz 652 hwnd 257280
ptr 259200 use 257280 sz 948 hwnd 257280
z id 115906160
Reply 629 of 896, by Peixoto
LukasThyWalls wrote:
Hi […]
Hi
32bit: 1
D3D: 3
dsk: 1280x960
gamma: 1
Gpadfix: 1
HD: 1
read: 1
Desktop 1280x960
OpenAdapter Hook 0
Show last 46 lines
Real : 1280 x 960
z id 115906160
Ok, i'll fix it on the next update
Reply 630 of 896, by 1024mb
It's there any way to make FMV's play filling the entire screen? I'm talking about RE2 (and possibly other games too, haven't tested more but I guess it does happen on other games). I'm playing at 1080p but cutscenes are played at original resolution on a tiny spot, I'm wondering if it isn't possible to play the cutscenes the same how video players do it, filling the entire screen (with or without maintaining original aspect ratio).
Thanks.
Reply 631 of 896, by Peixoto
Thanks.
The option to scale the FMVs will return to RE2 and other games soon
Reply 632 of 896, by stranno
Peixoto, Heart of Darkness only works with english 1.0 (supposedly 1.0) version, any chance to include 1.04 and 1.05 versions, as well as other languages?
Reply 633 of 896, by Peixoto
Where can i download those from ?
Reply 634 of 896, by BigShinyGloom
Hey Peixoto, thanks for all your work. As a heads up, your Google Drive link seems to be dead.
Reply 635 of 896, by Peixoto
Thanks for letting me know
Google says it violates their terms of service, i've submitted an appeal
Reply 636 of 896, by BigShinyGloom
Hmm, seems like the OneDrive link is dead now as well? That must have just happened, I was able to download it two days ago.
Reply 637 of 896, by Peixoto
Thanks, i fixed the onedrive link
Reply 638 of 896, by BigShinyGloom
Thank you for the quick fix
Reply 639 of 896, by Peixoto
Update:
Some bugs fixed on DX8 and earlier :
-Fixed some bugs on texture swapping introduced when the handling of DX6 and earlier was merged
-Restored the option to select the size of FMVs in some games
-Changed how frame rate limitation is implemented
-Forced resolution on DX8 doesn't disables MSAA anymore
-A Few other small things
Added support for DX9:
Forced resolution, as with other APIs, still has a low compatibility, but some games that befit a lot from it already work
New games added
- Half Life 2 (Dx9)
- FEAR
- System Shock 2 (DX9)
- Second Sight
Edit: forgot to fix resolution enumeration again. Next time
