First post, by Fujoshi-hime
So I'm gearing up parts for a 'Totally Inauthentic Windows 9X Machine', centered around the ASRock 775i65G R2.0. It's two SATA ports offer high compatibility with older OS's so using a SATA SSD and ODD should be no problem. Of course I could just buy a new SATA DVDRW drive no problem, but it'd potentially be handy to have a second BDXL drive on hand as I have many 100GB and 128GB BDXL discs holding archived backups. If I ever have to recovery off those discs, well, that's not the fastest media, would be handy to have a second BDXL drive on hand. So could I kill two birds with one stone and put an BDXL drive in a Win9X system? I'm not really interested in having it READ BluRays, CD and DVD will be fine, but then it's there to have me put it into service with a more modern OS and start ingesting backups into my main storage server again.
So just wondering if Win9X would even work with such a drive? Is it just about what discs it mounts?
Reply 1 of 8, by r00tb33r
"What would Windows 9X do with x?"
Reply 2 of 8, by The Serpent Rider
Blu-Ray file system is not supported.
Reply 3 of 8, by chinny22
Not that I own a blueray drive but I'd bet it would act just like a CD or DVD drive for the most part.
These guys had a bit of a play with blue ray discs in Win98, seems really hit or miss though.
https://msfn.org/board/topic/151108-blu-ray-u … der-windows-98/
You could test with a dos boot disk. If it works in dos then it'll probably work in Windows
Reply 4 of 8, by Fujoshi-hime
chinny22 wrote:
Not that I own a blueray drive but I'd bet it would act just like a CD or DVD drive for the most part. […]
Yeah, I'm wondering if it would just depend on what kind of discs it mounts. Where CD and DVD would work fine, but I ask it to mount a BD and it's like 'Yo, I don't know this version of UFS.' Which is fine really, the goal is not to run BD discs on 9X, it's to spend $80 on a second BDXL drive, rather than $80 on a BDXL drive I'll rarely use and then $30 on a DVDRW drive.
Reply 5 of 8, by appiah4
What filesystem do BD-ROMs use anyway?
Reply 6 of 8, by Fujoshi-hime
For a data disc, it's UDF 2.6, a 9X machine should support UDF, but looking it up, even 98SE and ME never supported better than UDF 1.02. I guess I'll just plug in my original BDXL drive and report my results. Though I imagine there's two likely scenarios; "HA HA NO." and "It's fine if it mounts a disc that's CDFS or UDF no higher than 1.02. But I didn't want to mount BDs on 9X anyway."
Reply 7 of 8, by Zup
There were unofficial UFS drivers for Windows 9x (Adaptec had one of those). Although I don't know what versions are supported, I guess that UFS 2.x won't be supported.
I'm selling some stuff!
Reply 8 of 8, by SirNickity
I can't say I've ever tried with a BD-R, but I do remember writing CDs and probably DVDs with ISO9660 and Joliet versions for back-compat, while retaining the flexible filename capabilities of UDF for newer OSes.
AFA using the drive as an over-spec'd CD-ROM, I don't see an issue with that. It should work(tm).
