First post, by imi
- l33t
So I'm going through my GPUs to label them and arrived at my Voodoo 3 PCI, it is a STB 210-0366-001 so I'm trying to find out if it is a 2000 or 3000 as they have the same model number so I can label it correctly... so I start searching around how to spot the difference, I guess it is a 3000 because of the bigger bare aluminium heatsink, but first I read about memory speeds, and my card has 183Mhz memory (HY57V161610DTC-55) which only the Voodoo 3 3500 runs at?
I read that the 183Mhz memory was expensive and sparse, so why would they use it on a usually lower clocked model?
looking around on google I found other PCI and AGP cards with 5.5ns memory.
...guess I'll have to test it out after all.
will any Voodoo 3 3000 chip do 183Mhz?
