I was receiving the error message: Could not find any fixed disk's...
because I had mounted my folder as the D drive. WizKid will only work if it detects a C drive.
nugget232 wrote:the included installer appears to crash (well it halts without preceeding any further once the install progress bar gets to the end)
This appeared to be happening to me. I left the computer for 5 minutes. When I returned there was a message stating that installation had been succesful. "Press any key to continue" or "Press F1 for help". Neither of these options would work for me. The mouse cursor changed when in DosBox so I don't think it was frozen.
nugget232 wrote:the following is displayed in the console: […]
Write 0 to rom at ffff9
Write 0 to rom at ffffa
and then nothing! the game just freezes.. HELP!
I get this error if I try to run the WIZKID.BAT file. Make sure you run the WIZKID\WIZKID.EXE instead with the loadfix option. You still get the errors but the game will start.
The bat file data is C:\WIZKID\WIZKID.EXE %1 %2 %3 %4 %5
Does anybody know what the %# instructions do?
If I use the "Game needs loadfix" option in D-Fend with
95Kb Unresponsive with slight glitches
97Kb glitchy
101Kb Seems to work but unresponsive.
104Kb Seems to work but unresponsive.
105Kb Seems to run but too fast.
106Kb Freezes on the Ocean logo.
107Kb Glitchy logo.
110Kb Running but unresponsive.
112Kb Glitchy.
114Kb Message: 114Kb freed.
115Kb Seems to run with slight glitch.
116Kb Seems to be running to fast.
117-8 Seems to be working but can't get anything to happen.
119-20 Buggy screen but recognizeable.
121Kb Freezes on the Ocean logo.
122Kb Buggy screen but recognizeable.
125Kb I get a lot of the "Write 0 to rom at" errors & DosBox crashes.
126Kb Seems to be working but can't get anything to happen.
128Kb Seems to work at first but has numbers in the top left corner.
129Kb Buggy screen but recognizeable.
130Kb Seems to be running to fast.
132Kb I get a Happy Birthday WizKid scene!!!
133Kb Buggy screen but recognizeable.
136Kb Intro only.
137-405Kb generates the message You must have 560k free to run this program. ###kb freed.
>406Kb maintains command prompt mode
I'm over this! If anybody wants to keep trying to test it, start at 94Kb & work your way down.
