Delusional performance of a 486 DX33
First post, by 21603
My memory must be playing funny buggers with me because I don't remember my old 486 running certain games as slowly as my new machine does.
Most 2D games it runs really well (almost like they were made for it) with some others being playable but not the greatest like Quake. Quake runs at about 4 fps, but is perfectly playable and very responsive unlike Duke Nukem 3D. Duke not only runs with what appears to be a lower fps but also stutters and is very unresponsive. It's Duke3D in particular that I remember being at least playable on my old machine and the hardware in that one was worse than my current build. Am I missing something or does Duke3D run like garbage for everyone else with similar machines. Lowest settings both in the settings menu and in game and I see no changes. Maybe my tolerance to play the latest and greatest games was just too overpowering and my brain told me than were at least playable. I even remember spending quite a bit of time making maps for it. Minimum requirements were a vague 486 with 8MB RAM.
Just wondering if maybe I'm missing some secret setting or my memory is not as good as I thought it was. Not that I was never expecting miracles from it, but I remember certain things running a little faster than they do now.
Intel 486 DX33
16MB RAM
Cirus Logic GD5428 2mb VLB
VLB I/O controller with UMC chip
Elitegroup UC4914-G motherboard /w 256K cache
Reply 1 of 35, by jesolo
Quake responsive and playable at 4fps on a 486DX-33? 🤣
At what resolution are you playing Duke Nukem 3D? Anything above 320x200 will be stuttering on all low to mid range 486 PC's.
Minimum requirements for Duke Nukem 3D is a 486DX2-66.
Don't expect stellar performance on a 486DX-33.
Reply 2 of 35, by maxtherabbit
do what now
Reply 3 of 35, by Errius
Quake really struggles on a 486, even a fast one.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 4 of 35, by 21603
jesolo wrote:
Quake responsive and playable at 4fps on a 486DX-33? At what resolution are you playing Duke Nukem 3D? Anything above 320x240 wi […]
At what resolution are you playing Duke Nukem 3D? Anything above 320x240 will be stuttering on all low to mid range 486 PC's.
Dont expect stellar performance on a 486DX-33.
It's perfectly playable for me, minus sound because that comes out of the speakers like something is being destroyed inside my PC. I think everyone should try Quake on a 486 for the experience.
Duke is running at the minimum 320x200. With even low details in game it's still not playable.
Bottom of the box says 100% IBM or compatible 486 PC with 8MB RAM. It probably should say DX2/66 as a minimum.
Reply 5 of 35, by The Serpent Rider
Authentic low-end PC experience has gone too far!
Reply 6 of 35, by pewpewpew
Aye. Not all of childhood is worth revisiting.
That said... I admit i don't mind how my P4 sags when UT2K4 gets busy. That falling framerate fitting with the adrenaline surge just feels like the game did - all warm memories.
Reply 7 of 35, by BinaryDemon
Other than even attempting Quake, your DX-33 experience matches my memory. I recall Duke3D studdering occasionally on a DX2-66. I tried Quake on my DX4-100 but I couldnt handle the 9 fps. It really wasn’t until I had a Cyrix P200 w/ Rendition Verite 2100 that I finally played thru GLQuake.
Reply 8 of 35, by jmarsh
Don't forget Duke3D also has a screen size setting (as well as resolution selection) which makes a significant difference.
Reply 9 of 35, by RaverX
Quake on 486 is not playable. Not even on DX4 100 and not even on AMD 133. You really need Pentium for Quake.
Duke3D is ok on DX4 100, but on DX2 66 is not a great experience, it runs, but everytime there's a few monsters and you start shooting it will slow down too much. And on DX33 its not playable.
Reply 10 of 35, by leileilol
eh, quake on a high-end 486 was fine. that's how I beat it (and even played online). 11-20fps was perfectly acceptable in the day.
DX33 on the other hand i won't even think about it. Descent should be enough of a wake-up call.
Duke3D IIRC was much about the sudden on-demand disk access getting in the way for low specs. Quake precached all necessary assets on load.
Debian's fucked
Reply 11 of 35, by HanJammer
Even if something is possible it doesn't mean - it's right thing to do.
Both Quake and Duke3d are very late 486 and Pentium games. Almost everybody had like 486DX4-100 or Pentium 133 when these titles were released. Some guys had Voodoo cards just few months after (for glQuake). There's absolutely no point in trying to play Quake on something as slow as 486DX33 - it's early 90s machine for 2D games (Doom) and early 3D games (like X-Wing). Same applies to Duke3D.
I recall that my friends at highschool who had DX4-100 CPUs complained constantly about low FPS in Quake and Duke3D, and they played it in reduced resolution (or in high res, but reduced window/viewport size) as these were pretty much reserved for Pentium machines. At the time I had 286 (and switched to K5-PR133 in the early 1997) so it didn't really bothered me much. ;D
Reply 12 of 35, by sf78
Agree. I recently tried to play Their Finest Hour on a stock A500 (like I did back in -92) and it was just abysmal, like 3 fps max. I can't believe I spent hours and hours playing it back then. 😵
Reply 13 of 35, by derSammler
I even beat Wing Commander on a stock A500 back then. 😁
Reply 15 of 35, by appiah4
Stop posting drunk.
Reply 16 of 35, by 21603
Not playable it seems to many of your standards, but 25 years ago that was all I had and I wasn't going to let anything like borderline negative fps get in the way of me playing a game 😎
Doom is another one that I remember running much faster, but I think I've proven that my memories of such events have been altered by time to appear much better than the reality showed.
I was worried that my machine might be lacking in some way to my original despite better hardware.
A CF card wouldn't be hurting performance in any way would it?
Also back in the day I was stupid enough to install Windows 95 on my machine and play the demo for Jedi Knight. Quake runs better.
Reply 17 of 35, by jmarsh
Not if you've got 16MB of RAM... assuming you do have smartdrv running?
Reply 18 of 35, by HanJammer
BTW I've read somewhere that scientist have a theory why people complain about the time going faster with age. The article said it's because when we are younger we process images faster (our brains have higher frame rate ;D ) so in the same unit of time we gather more information (and adults gather less information so the time appears to move faster). Same process is responsible for having a vivid childhood memories.
If it's true then as a child lower fps in game should be perceived as less smooth then 😉 but I guess that amusement and excitement of playing these games as kids was more important back then than high fps 😀
Still it's just a theory... a GAME THEORY 😉
Reply 19 of 35, by Cyberdyne
So strange to think i played all full Quake in 1996 from start to end with software rendering 320x200 and with a 486 DX-2/66 god, back in the day we were true masochists. 😵 I got a Pentium 133 in 1998... everything flied in there, but another sadistic period started, Half-Life with a Pentium 133, thank god i had a Voodoo to help me a little, but the in game loading times were miserable.
