Reply 40 of 48, by Glidos
- l33t
I believe you, but interactions within a program are very complicated, so it doesn't have to be the letters that are at fault.
What if you run with just the letters and the equiv file?
All the same. :dead:Also it appears without equiv and mapping files.
Ah good. Can you take exactly that version of Textures, you have crashing now (which presumably isn't very big), and post it here for me to try.
I could try building it from what you have already posted, but that just introduces the possibility of errors.
I told you: It crash on Letters file( that one that I post), or you think some others textures?
Anyway I can't login on website for which you send me password and username. What's the point?
Those were FTP details I gave you. You need to upload using an FTP client.
The point is that neither of us has time to waste. It is important that I investigate this problem using exactly the same Textures folder that you are having the problem with.
If we do that by you zipping the Textures file exactly as you have it now, and sending it to me, then we can be sure that I am working with the same thing as you.
If on the other hand I follow your instructions on how to build the Textures file by combining the Letters folder with the equiv file then there is all sorts of room for error. Your instructions could be wrong. I could follow them wrong. Its a waste of time doing it that way.
In any case, if you are seeing the problem with just those textures and the equiv file then you have a very small Textures folder that could be uploaded here, and save the messing about with FTP.
😕 😕 😕 I told you, letters file causes the problem. I was post it so…
Ok, we can try it your way I guess.
So what should I do next towards fixing this problem?
I've just tried taking the textures from the Letters archive you posted and putting them in
C:\Program Files\Glidos\Textures\EFE6179F82CA4471725D4532BC8AA60D
In addition, I put the equiv file you posted in
Is that right? When I run like that, I see your letters in all levels and I get no crashes.
What should I try next?
What! You do all wrong!
I just joking man! No bad filling. Sorry. Ok 😉 (Man I just go to die laughing 😁 😁 )
I will try with older version of Glidos to see is this thing persisting. Also I will upload my tex. files (this I should do earlier, isn’t I )
Hey, no worries. I just hate these bugs. I wanna go squash them.
