Snover wrote on 2020-01-01, 02:02:
Thanks for noticing the problem with the attachments list. I was able to reproduce an issue when deleting the penultimate item, which should be fixed now. Let me know if you still have problems with that.
Thanks for fixing the first issue. On further testing, I get the behaviour below:
After loading/ deleting multiple images to your post editor, I've noticed that the 2 different ways to preview your posts behave differently:
The top icon highlighted in red doesn't seem to refresh your updated post content with images and still shows old images. The bottom preview highlighted in green does refresh your post content with updated images. Please can you look into this as the top preview is the most convenient one to use by being the closest to switching between preview and post view. This behavior with the preview buttons is after deleting images. Otherwise, these buttons seem identical.
Snover wrote on 2020-01-01, 02:02:As far as the broken text editor goes, let me make sure I understand what you are saying by repeating it back at you: […]
Steps to reproduce:
1. Upload an attachment
2. Press the “inline attachment” button to insert the attachment to the post
Result: The [attachment] tag does not show up in the text input. However, after previewing the post, or saving and reloading the post as a draft, the [attachment] tag is shown in the text input.
Is this right?
Regarding point 2, the result is this below:
You can see the attachment tag isn't showing above the underlined red in the post editor. This behavior happens when my phone is in portrait orientation. If I preview this post, the inline image is previewed correctly.
However, I've noticed that when in landscape orientation:
You can see the attachment tag showing above the red line in the post editor as it should.
If I save a draft on reopen to work with, in my previous explanation, I may have switched phone orientation and inadvertently fixed the issue.
Another note, if I save a draft with inline image tags in the post editor, their corresponding uploaded images aren't saved. When I re-open the editor, their tags are still present in the post editor, but images are missing.
If I re-upload these images again and try to use the post editor, their inline post placements don't work for their corresponding image tags. I have to delete their image tags from the post editor and replace the same image tags again. Any way to improve this draft behaviour? Drafts would be saved for complex posts with many images. Thanks in advance.
