First post, by Intel486dx33
What type of ram to use in a 486 computer ?
Parity or Non-parity ?
Reply 1 of 4, by ifrit05
No pro's to using parity ram if not running in a mission critical system, I'd go with non-parity, but get whatever is cheapest.
P3B-F v1.03 | VIA C3 Nehemiah 1.0A @ 500/66 | 128 PC133 | GeForce 256 SDR | PicoGUS+Yamaha OPL3-SAx | FreeDOS 1.3
Reply 2 of 4, by Grzyb
Use what was the most common...
30-pin SIMMs - with parity
72-pin SIMMs - without parity
Though they may be some machines (Compaq comes to mind) with 72-pin sockets which require parity.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 3 of 4, by appiah4
Use FPM instead of EDO unless you are sure the board supports it, otherwise parity makes absolutely no difference in 99.9% of cases.
Reply 4 of 4, by mdog69
appiah4 wrote on 2020-01-02, 06:57:
Unless your 486 motherboard only supports parity RAM.
(Dell 425/P 4 72pin slots, treats 8Mb parity as 4Mb, so I've got a 16Mb PC, instead of the 64Mb one I'd have if it took non-parity devices...)
