First post, by MMaximus
Managed to install a MFM hard drive in my Turbo XT recently 😀
I found a WD1002A-WX1 8-bit MFM interface in a bag of parts I got given when I bought a lot of systems a while ago. In the bag was also one of these bezels to stick on the front of a hard drive in order to mount it in a 5.25" bay. I always liked the look of these things - from the bygone era when there were no internal bays in PC cases and HDDs had to be mounted in the floppy drive bays...
I had this spare 20Mb Kalok KL-320 MFM drive I removed from a 286 machine. I tried installing it in my XT with the WD interface but it wouldn't work. Checked the jumpers, they appeared to be set up correctly so I burned the "F300" Bios (found here) on an Atmel chip and stuck it on the card. Still wouldn't work. The MFM drive was working in the 286 machine, but I understood I needed to low-level format it in the XT for the computer to recognize it. After summoning the formatting utility from the WD BIOS and formatting the drive, it was just a matter of FDISK and format... and now I have glorious MFM soundtrack in my XT 🤣
Curious to know if any of you are also using MFM drives in your XT systems? How do you deal with file transfers? I was using an XT-IDE-CF card before but of course it can't work with the MFM interface so I'm sacrificing easy file transfers and also HD floppy support. I plan to get around that by installing an 8-bit network card in the system and using mTCP.
Also, since the case only has two external bays I'm sacrificing dual floppies. I need to find a working 5.25" 360k black drive - this one in 1.2M and doesn't seem to read disks. I could also hide the MFM in the third bay (internal) but then it wouldn't look as vintage 🤣
Hard Disk Sounds
Reply 1 of 20, by Grzyb
I think majority of XT users use MFM HDDs, myself included.
As for file transfer, I usually use LAN, but I also keep some later machine with a 360KB FDD - after all, the networking software has to be somehow installed on the XT's HDD first...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 2 of 20, by Errius
All you need is a parallel or serial cable to establish basic connectivity between an early DOS computer and a later one. So long as the newer machine has INTERLNK/INTERSVR (i.e. DOS 5 or 6) you're good to go.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 3 of 20, by manbearpig
My Vtech Laser XT Turbo has the famous ST225, though I have never gotten it to read. The motherboard has been in the repair pile for a while, been hacking away at it over the years. Doesn't need too much more.
Premio 212B motherboard (MSI MS-6112)
Intel PentiumII 333MHz Slot 1 66MHz bus
384MB ECC 66MHz
SIIG ATA133 controller --> Seagate Barracuda 80GB
SIIG Gigabit Ethernet (RTL8169) / USB 2.0 / IEEE1394 controller
ESS 1869 soundcard on board wavetable synth
Reply 4 of 20, by Caluser2000
Gave up on MFM drives. Fitted a XT-IDE card. A lot more choices and a BigFoot hdd fits nicely in the drive bay.
Reply 6 of 20, by maxtherabbit
my IBM 5150 is equipped with two working ST-225s in the left full height bay, and dual floppies in the right bay
I use a WD8003 NIC and mTCP for file transfer, it's honestly easier than moving a CF card around and the FTP programs have no problem saturating the disk I/O
Reply 7 of 20, by PTherapist
My IBM 5160 XT build has a Seagate ST-225 MFM drive.
For file transfers I use mTCP's FTP server.
But I also have XTIDE installed on an EEPROM chip on my Ethernet card, which allows you to mount & boot virtual floppy & hard disk images over the Serial port. So this can be used as another method for file transfer, though I mostly just use it for running PC Booters.
Reply 8 of 20, by maxtherabbit
mTCP is the gold standard, if you have a slot for a NIC anything less is really just inferior
Reply 9 of 20, by Anonymous Coward
I no longer use MFM. Now it's a combination of SCSI and SCSIDE + CF card.
My old MFM setup was pretty cool though. At one point I had dual ST-251s, which normally format to about 40mb each. However, I stuck them on a WD1002A-27X RLL controller, and I think each of them became 52mb. I can't say I really recommend dual MFM drives though, because it's pretty noisy.
I currently only own one MFM drive. It's a 10MB IBM drive that was the original drive with the XT. I haven't powered it on in 20 years and I'm not even sure if it still works!
Reply 10 of 20, by maxtherabbit
one man's noisy is another man's beautiful symphony
I think old HDDs sound wonderful, the more the bettter
Reply 11 of 20, by Scali
I think I had that same Kalok MFM 20 MB drive in my Commodore PC10-III. The controller also looks similar.
I no longer have that machine though.
I do have an MFM machine still. That is my IBM 5160 from 1987. It still has its original 20 MB Seagate MFM drive in there. The controller card looks much larger and oldfashioned than that one.
File transfers are done with a serial nulmodem cable using FastLynx, to my modern PC with a USB serial cable.
Reply 12 of 20, by canthearu
I've got a HP Vectra CS computer with a V30 processor.
It has a 20meg MFM hard drive, Seagate ST-251, in pretty decent nick. The MFM card does not come with a BIOS, but the HP has built in support for this card.
I use the MFM card for booting and DOS isntallation, but I have a 4gb CF card and XT-IDE card for bulk storage.
Other cards in this computer:
a) NE2000 compatible card for ethernet in 8bit mode.
b) Sound Blaster 2.0 clone card (Sound magic)
c) Some strange Instrumentation card with HP-IB port and onboard 68000 processor.
Reply 13 of 20, by mbbrutman
Let's not get carried away 😉
Reply 14 of 20, by keropi
Yes, it's not like people have bootdisks with the ftpserver and use it with every old system they get 🤣
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 15 of 20, by MMaximus
Nice to see these old MFM drives still being in use 30+ years later! 😎
Thanks for the suggestions about the file transfer methods. I actually didn't know about Interlink or Fastlynx.
In the mean time I did get two different 8-bit ethernet cards - a 3com Etherlink II and a WD8003. Both work with mTCP and it makes transferring files to the MFM drive a breeze. mTCP truly is amazing... thanks Mr. mbbrutman 🤣
Now I just need to find a working 5.25" FDD. For some reason there are games that don't seem to work when launched from the hard drive, but work from a floppy disk.
Hard Disk Sounds
Reply 16 of 20, by gordesky1
I have a VTECH LASER TURBO xt will a XT-IDE Rev 4.1, ISA 8-Bit IDE Controller work in it? or a compact flash one? Right now it just has the 2 5.25 inch floppy drives and they can be a pain if they wear out mainly the boot floppy 🤣
Would be nice to load all the games i have for it on a storage device Sense when i got this pc free in like 2000 it came tons of 5.25s with games on them and with the keyboard joystick and also the Magnavox monitor. everything still works to this day:)
Reply 17 of 20, by Horun
Nice that you have a good working XT computer ! Yes you should be able to use XT-IDE r4 on your Laser XT, it would go in same slot as the current HD controller. The CF versions should also work fine. Only problem is what OS you run as Dos 3 supports up to 504MB HD in the OS, DOS 5 and up supports 2Gb so you will want a small HD (for r4) based on my experience. Am sure there are others that give better info.
Reply 18 of 20, by Caluser2000
Any Dos lower than PC/MSDos 3.3 can only have partition sizes up to 32 megs in size, Something to consider when choosing your Dos version. I'm using DrDos 6 on my XT-Turbo clone with 8=bit XT-IDE card and 2 gig hdd.
Reply 19 of 20, by Jo22
^Except for some ancient OEM versions of DOS which used non-standard sector sizes and partition types. 😉
