Frontier: Elite 2
First post, by snoopreg
I can get this game running just fine, but it lags quite a bit through out the entire process once the game is running... what should I do?
I have the latest version of Dosbox and I use D-fend v2, what settings should I use?
Reply 1 of 3, by Shed
try set Cycles Up (Ctrl+F12) to 15.000 cycles...or so...
or
try this dosbox.conf (0.65) file
[SDL]
fullscreen=false
fulldouble=false
fullresolution=original
windowresolution=original
output=ddraw
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
[dosbox]
language=
machine=vga
captures=capture
memsize=32
[render]
frameskip=0
aspect=false
scaler=normal2x
[cpu]
core=dynamic
cycles=16000
cycleup=500
cycledown=20
[dos]
xms=true
ems=true
umb=true
[mixer]
nosound=false
rate=22050
blocksize=2048
prebuffer=10
[sblaster]
type=sb16
irq=7
dma=1
hdma=5
oplmode=auto
oplrate=22050
mixer=true
[midi]
mpu401=true
device=default
[gus]
gus=true
gusrate=22050
gusbase=240
irq1=5
irq2=5
dma1=3
dma2=3
ultrasnd=C:\ULTRASND
[speaker]
# pcspeaker -- Enable PC-Speaker emulation.
# pcrate -- Sample rate of the PC-Speaker sound generation.
# tandyrate -- Sample rate of the Tandy 3-Voice generation.
…Show last 45 lines
#              Tandysound emulation is present if machine is set to tandy.
# disney -- Enable Disney Sound Source emulation.
pcspeaker=true
pcrate=22050
tandyrate=22050
disney=true
[bios]
# Nothing to setup yet!
[modem]
# modem -- Enable virtual modem emulation.
# comport -- COM Port modem is connected to.
# listenport -- TCP Port the modem listens on for incoming connections.
modem=false
comport=2
listenport=23
[directserial]
# directserial -- Enable serial passthrough support.
# comport -- COM Port inside DOSBox.
# realport -- COM Port on the Host.
# defaultbps -- Default BPS.
# parity -- Parity of the packets. This can be N, E or O.
# bytesize -- Size of each packet. This can be 5 or 8.
# stopbit -- The number of stopbits. This can be 1 or 2.
directserial=false
comport=1
realport=COM1
defaultbps=1200
parity=N
bytesize=8
stopbit=1
[ipx]
# ipx -- Enable ipx over UDP/IP emulation.
ipx=false
[autoexec]
#This lines the autoexec bat file
Reply 2 of 3, by snoopreg
Thanks!
Runs much better now! Classic game, too. 😀
Reply 3 of 3, by Shed
of course, it's a game classic of all times....but very difficult to learn how play with it....
but one of first three dimensional universe-simulators for pirate, or commerce etc
