Reply 32160 of 52911, by mockingbird
Thermalwrong wrote on 2020-01-03, 00:08:Do you have a printer to print them for yourself? I'd forgotten about it, but I did design up a replacement bezel to fit the external drives so they can go in a regular case. They turned out pretty well
Otherwise I could print up a few to sell since I've got both the beige filament and the transparent filament needed.
Does your offer still stand? I ask because I messaged you but I've not yet received a reply. Also because I picked up another LS-120 today. This time from a parallel port enclosure. This time the model is LKM-F433-1 as opposed to LKM-F933-1. The older model draws 1.7A instead of 2.7A. IT also has a manufacturing date of April 1997.
One difference that may pertain to the design spec of the bezel is that the "lip" - for lack of a better way of putting it - on the mettal chassis above the flap is 24.05mm wide, as opposed to 13.36mm for the newer model. If you count the total amount of space around the lip on the newer model, it also looks to be 24.05mm.
