First post, by p6889k
I'll be getting 200mhz 256kb cache Pentium Pro. Can this cpu run without any heatsink and cooler? If it needs a heatsink, are heatsink for any other socket type compatible with socket 8 ? I'm having hard time finding socket 8 heatsink.
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 1 of 7, by maxtherabbit
yes they run toasty it will destroy itself without HSF
Reply 2 of 7, by bofh.fromhell
p6889k wrote on 2020-02-02, 23:30:
Doesn't need much, but it still needs one.
Also I belive theres some AMD socket coolers that fits fairly well, need to DYI a fastener tho.
Reply 3 of 7, by Sedrosken
110% absolutely yes. I believe they start at 30W and only go up from there -- so the lowest-end ones you can get away with passive cooling, but if you overclock at all and/or have a 1MB cache model, they have TDPs of around 45-50W, so you *must* use a fan (or, I suppose, an inordinately large passive heatsink).
Shoushi: Dimension 9200, QX6700, 8GB D2-800CL5, K2200, SB0730, 1TB SSD, XP/7
Kara: K7S5A Pro, NX1750, 512MB DDR-286CL2, Ti4200, AU8830, 64GB SD2IDE, 98SE (Kex)
Cragstone: Alaris Cougar, 486BL2-66, 16MB, GD5428, CT2800, 16GB SD2IDE, 95CNOIE
Reply 4 of 7, by derSammler
Heatsink yes, fan no - if the heatsink is large enough. My 200 MHz PPro came with an OEM heaksink only installed and no fan.
Reply 6 of 7, by p6889k
Thanks everyone for the advice. I ended up ordering one from eBay and then I'll mount one of the many small fans I have around.
etc.
Reply 7 of 7, by The Serpent Rider
Technically it's just better to obtain the cheapest option with the socket clip included and mount some decent Socket 370/Socket A cooler instead.
