Troubleshooting Asus PCI/I-P54SP4 no boot
First post, by dionb
Today I picked up a board hoping to test P66 vs P75 head-to-head in as near identical hardware as possible (So4 and So5 Asus boards with SiS501 chipset). Of course, that is only going to work if the boards actually work. The So5 Asus PCI/I-P54SP4 is pretty DOA :'(
Here's the board:
file.php?id=76479&mode=view
Ignore the SIMMs at an angle, I've replaced them with two known-good 32MB SIMMs, from my PCI/I-P5SP4 (identical to this one except for voltage regulator and socket). I've also added a Diamond Stealth3D 2000 (S3 Virge PCI card), and hooked up a keyboard. That's all.
Symptoms:
I power on the AT PSU and nothing happens - POST card resolutely sticks at 00, no image via VGA or any other sign of life. CPU gets warm.
What I've done so far:
- checked jumper settings: correct for P75 and double-sided SIMMs. Bus speed set to 50MHz
- checked fuse by keyb controller: <0.1Ohm
- checked the voltage planes on the board:
+5V = 4.86V - lower than I would like but within 5% tolerance (>4.75V)
+12V = 11.66V - not bad, well within 5% tolerance (>11.4V)
- measured output of VRM: 3.43V - spot on.
- swapped BIOS chip for a newly flased version 0106 0204 0106 was confusion with P5SP4... (newest from Asus site) - no change
- swapped CPU for another P90 - no change
- disabled I/O and (awful) CMD IDE - no change
- looked for obvious damage to both sides of PCB and components - nothing I can spot
The Dallas RTC is an obvious suspect, but at the same time it's a DS12887, not a DS1387, so it shouldn't cause anything worse than not saving settings. It's soldered, not socketed, so can't immediately swap it out. Don't want to attempt to de-solder unless I absolutely have to.
Any other suggestions for things to try?
Reply 1 of 26, by Horun
Did the KB led's flash briefly when first powered ? Have you tried a speaker to see if it beeps or screams, just in case the POST card has a compatibility issue with that board ?
other than those I got nothing.
Reply 2 of 26, by mpe
My SiS501 board doesn't boot if SIMMs are only installed in the second bank (top two slots on my board, just like you have them inserted).
Also the chipset doesn't support 32MB SIMMs you mentioned. 16M is the max you can use as there are only 12bit raw/column signals
Blog|NexGen 586|S4
Reply 3 of 26, by dionb
Horun wrote on 2020-02-09, 16:21:
Not a peep from the speaker. The LEDs flash very briefly immediately at power-on.
Strongly doubt a compatibility issue with the POST-card, as I have two and both work fine on the P5SP4.
mpe wrote on 2020-02-09, 16:25:
On the Asus P54SP4 and P5SP4 the top two are bank 0. It works on the P5SP4 with the SIMMs in bank 0. To be sure I also tried bank 1 on the P54SP4, but same result as with bank 0.
Oh? As I said, these SIMMs came from my P5SP4, with the exact same chipset, where they happily give me 64MB total. They are double-sided 32MB modules, so each chip is only 16Mb (4Mx4).
Reply 4 of 26, by mpe
If double-sided it should be OK. I mixed bits and bytes
Blog|NexGen 586|S4
Reply 5 of 26, by Horun
How about bad a BIOS chip or flashed with wrong bios image ?
Reply 6 of 26, by dionb
Horun wrote on 2020-02-09, 17:32:
Flashed a second EEPROM with the latest image from the Asus site. No change.
Reply 7 of 26, by Nvm1
This board still has some tantalums on it. Check them, they like to fail/short without being visible or they go out with a loud bang.
Reply 8 of 26, by dionb
Nvm1 wrote on 2020-02-09, 19:12:
No really loud bangs and did a visual check too...
Good idea though, I'll check for resistance over their points (not perfect when in situ, but should show difference between short and workgin)
Reply 9 of 26, by TheMobRules
I am troubleshooting a Socket 5 board with the exact same symptoms, only it's a Neptune (430NX) based board (FIC PN-2000). I also tried flashing the latest BIOS on another chip, several known good PCI/ISA VGAs, CPUs, PSUs and FPM memory sticks but no dice. Voltages are fine but POST card doesn't budge from '-- --'. The former owner claims it was working just days before he removed it and gave it to me, but since I got it for free I have no reason to doubt him.
It also has a soldered DS12887 block (they really did like these things during the mid-90's!), so as a last resort I decided to desolder it with my cheap ZD-915 gun, knowing these things sometimes prevent boards from booting. Luckily it came out very cleanly. Once I get DIP24 sockets I will solder them in and test again with a known working (and CR2032-modded) DS12887. If it works it may also be worth for you to desolder it.
Reply 10 of 26, by mpe
The Dallas shouldn't have created this. With a dead battery start the board should still start and display an error. Even with failed Dallas (or no Dallas at all) the POST card should display at least something as it should fail half way in the POST (although the board wouldn't be displaying anything).
But everything is possible.
Blog|NexGen 586|S4
Reply 11 of 26, by dionb
Everything is certainly possible, but it would be a first for a DS128(8)7 not to boot at all. From PS/2 model 30 to Asus P55T2P4, boards with those beasts just get offended at lack of settings. It's the DS1387 RealtimeRAMified boards that sometimes utterly refuse to do anything if the battery is dead.
Checked the caps - can't be totally sure that they are still doing their capacitive job properly in-situ, but none are completely shorted. Scratch that one...
Am now wondering about clock signals. Unfortunately I don't have an oscilloscope to check them 🙁
Reply 12 of 26, by quicknick
Does your POST card have a "Reset" led? Does it turn off shortly after you apply power?
Do you have means to measure the clocks on the board (ISA, PCI, CPU, KBC)? - edit: typed that while you were typing 😀
Try powering up your board while applying some pressure with your thumb to each big chip, if this changes anything then you have bad/cracked solder joint(s).
Reply 13 of 26, by Robin4
I purchased two of these boards myself..
What could help is remove DIP chips from there socket and put some IPA 99,9 procent in it with a cotton stick. And also trying to clean the legs of the chips.
Sometimes the connections of these chips are getting very bad of corrosion..
Also put IPA on the flat pack chips en try to clean them.
Did you also tried the third and the fourth memory bank?
The latest bios is 0204..
Use the attachments on your own risk.
The board also dont work maybe because of a bad memory bank which is damaged.
As last option is maybe to reflow the solder joints. Maybe it give you some light in the darkness.
Reply 14 of 26, by breno785au
Just restored a system with one of these motherboards in it, glad to say it POSTs but BIOS reporting CMOS battery fail. But i'll be damned if I can find the battery!
Reply 15 of 26, by Doornkaat
breno785au wrote on 2020-02-23, 12:08:
The battery is inside the Dallas RTC module in the bottom right corner. You can replace the module or hack an external battery to it. Googling "Dallas RTC bettety hack" should give you plenty instructions. Have fun! 😃
Reply 16 of 26, by breno785au
Doornkaat wrote on 2020-02-23, 19:34:
I thought it might be something like that, thanks for letting me know!
Reply 17 of 26, by dionb
Robin4 wrote on 2020-02-10, 00:48:
I purchased two of these boards myself.. […]
Hopefully will have time to try this later this week.
There are no third and fourth bank - this is a Pentium board so two SIMMs = one bank. The bottom two are bank zero, the top two are bank one. Tried both. No change.
In my OP I mixed up the numbers of th P5SP4 and P54SP4 BIOS versions (I have both, the P5SP4 works fine). I'll correct OP and try yout 0204 image just to be certain.
Not much risk with an EEPROM flasher 😉
Possibly, but as I've tried both banks (with known-good SIMMs that work on the P5SP4) they would both have to be damaged. No sign of damage to the traces around the SIMM slots.
Would like to have an idea exactly which chip(s) need this before I do that, but lacking an oscilloscope I can't get much further than checking continuity between GND and 5V lines at pins, which shows good everywhere I've done so far.
Reply 18 of 26, by breno785au
This sounds like a stupid question but I wouldn't have to configure any of the drives in the BIOS for this motherboard right? Motherboard isn't detecting any IDE drives, have confirmed they work in another system...
Reply 19 of 26, by kixs
Usually you have to set the parameters in the BIOS. Via auto-detect feature or set to AUTO in the Standard options.
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
