Reply 20 of 58, by Planet-Dune
Errius wrote on 2020-02-09, 22:16:Right, so it has two 5.25" floppy drives and you want to add an external 3.5" drive. Does it have a hard disk?
If you have another DOS machine with a 3.5" drive you can connect them via parallel cable and transfer files that way.
Well I wanted to add the external drive to a modern pc that does have usb support (my 98 pc or something) and then transfer the written floppy to the commodore.. my pipe dream was that there would be USB models just as there are for 1.44" diskettes but that seems a big no go. I do have a 386 with a diskette drive but not a floppy 🙁
