Reply 340 of 501, by matze79
just write me a PM.
Thanks
Matthias
Reply 342 of 501, by matze79
But you can read them right ? 😀
Reply 343 of 501, by matze79
Paku Paku (SN76489) with modified Sound.pas
tandy.exe /sn76489 for SN76489 Cards on 0C0-> Prevents Tandy Check.
The attachment paku_tndy.zip is no longer available
The attachment src.zip is no longer available
Thanks to Lothar / Fratzengeballer for modifying the Code.
Reply 344 of 501, by 8088mph
I would still like one. I posted here already and also tried emailing admin at retroianer dot com but never heard back.
Reply 345 of 501, by matze79
Hi reaper, can`t answer you.
your Email filter is gone wild.
Reason: Regex: bombRe 'PB 20: for cheap' bombRe: 'cheap'
Reply 346 of 501, by keropi
according to tracking my card awaits at home 😁
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 347 of 501, by matze79
parts! 😀
Reply 348 of 501, by keropi
I made the time and assembled my card 😀
(hope the fix is indeed this)
I have not tested it yet, what do I need to get it working? Anyone has a patched game or something for testing this?
very nice kit overall matze79, thanks!!!
Reply 350 of 501, by matze79
you should also fetch 3tool (aka sndoff previously..) and you could try Paku Paku patched above,
or sbvgm / vgmplay.
Paku Paku
download/file.php?id=76326
( tandy.exe /sn76489 )
3tool
download/file.php?id=74403
Reply 351 of 501, by matze79
And:
The attachment TESTTNDY_XT.zip is no longer available
- Hercules Graphics fixed.
Reply 352 of 501, by keropi
just tested it and it's brilliant! 😁
tested in my 233mmx build using 0C0h address , Paku Paku worked fine but that test program just froze the system... I remember this from the TNDLPT prototypes and I can't say I like it very much... it misses the ability to play a test tune (or I have not found yet how to do it)
I want to use the TNDY card in my main build now but I am waiting for some patches collection that will allow a different address than 0C0h so it can be permanently enabled without issues.
great little card matze79!!!
Reply 353 of 501, by root42
You can always use the TSR or EMM386 to remap the port. Since basically all Tandy games are real mode, this should be no problem.
YouTube and Bonus
Reply 354 of 501, by keropi
nah , the best way is to have patched drivers no tsr and extra stuff on top 🤣
I will wait for a good patches package 😀
Reply 355 of 501, by matze79
The TSR will never go to offer 100% compatibility
The Test Program Freezes ?
maybe you can try a older version.. i will attach one. Maybe it has to do with latest additions ?
The attachment testv03.zip is no longer available
A great way for AT`s is using a 3 Pol Switch connected to JP1, so you can change beetween 0C0 and 0E0 as needed.
i also tried some game patching but where not very successful.
i disassembled Civilsations Tandy Sound Part, and now installed IDA Freeware.. but i can`t seem to get it properly.
Seems Civilisation has some kind of self integry check.
basicly i tried to find all 0C0.. and replace them with 0E0..
Reply 356 of 501, by keropi
well tested it again without running anything and it worked with no freeze
could be many things, mainly 0c0h in ss7 system
would be great to add a button with a test tune though for fast results
it is my belief that the card will be more "valuable" if supported games could be patched and work without issues in all systems with no extra software...
I know this will begin to sound like a broken record but that's something unavoidable IMHO... I am not a software guy else I would be all over this 😁
Reply 357 of 501, by matze79
Yeah best is to stick the card into a XT 😉
this will give you best possible compatibility.
Here is the Test Tone Generator 0.1, but it does not support every port number
The attachment TANDYTES.EXE is no longer available
its not yet implanted into tandy test tool, when jan knipperts has more time he will finish the tool.
Reply 358 of 501, by keropi
matze79 wrote on 2020-02-13, 12:17:
even then isn't there the issue of tandy bios/machine checks?
Reply 359 of 501, by matze79
yeah here you can patch the system bios rom.
the most important issue is the lack of tandy video card 😁
many games only will give you tandy sound with tandy video.
later titles also supporting vga upgrades and so on should work fine then.
