Reply 362 of 390, by matze79
8088mph wrote on 2020-02-14, 18:17:
Got mine today. Waiting on PC speaker cables but the audio out jack works.
Which VGM files are compatible with the card? Is there a collection somewhere?
very good!
usually you can also use a CD-Rom Audio Cable for Connection.
as i only play games with the card (mostly) i have not packaged up a collection i just have 3 vgm files.
But there are many vgm download sites on the net, i don`t even know if they are legal.
its also possible to convert midi files to vgm.
https://vgmrips.net/forum/viewtopic.php?t=1929
At least there are 2 Players,
sbvgm and vgmplay
@NitroRaptor
you can`t PM until you have some posts.. i don`t know the exakt amount right now.
Co2 - for a endless Summer
Reply 364 of 390, by matze79
all cards and kits found owners 😀 as promised everyone will get a chance to gain a card soon.
There will be a official way to obtain one!
Reply 366 of 390, by matze79
https://www.youtube.com/watch?v=KJ6PgTIf00o
root42 will do Live Soldering of tndy card
EDIT: Date changed:
28. Februar, 20:30 - Central European Time
Enjoy the Show!
Reply 368 of 390, by dreamblaster
root42 wrote on 2020-02-28, 19:28:
Live Stream starting in 2 minutes 😉
Watching !
OPL2LPT, OPL3LPT, X2, S2, S2P, MCE2VGA, ... many projects !
Special vogons LPT bundle : https://www.serdashop.com/Parallel-port-retro-sound-bundle
Thanks for your support !
Reply 369 of 390, by root42
And one sample of the new card, Populous:
https://youtu.be/3uMBLuBFr_g
Apart from me being confused by the labelling of the components, it turned out really well! Thanks, matze!
YouTube and Bonus
80386DX@25 MHz, 8 MiB RAM, Tseng ET4000 1 MiB, SnarkBarker & BlasterBoard, PC MIDI Card + SC55 + MT32, XT CF Lite, OSSC
Reply 370 of 390, by matze79
What device do you use for recording ?
@fagear what vgm files did you test ?
Sonic Title ?
Reply 371 of 390, by root42
matze79 wrote on 2020-03-02, 12:12:
Were you referring to me? In these new videos I use a 3 channel Behringer USB mixer to capture the audio. Before I was using the OSSC with a USB3 HDMI capture card.
I added a few more videos to my second channel using the new card:
https://youtu.be/l3cyuRbzKCM
https://youtu.be/R_TJoeK3EqQ
https://youtu.be/Okonh3xdAFc
YouTube and Bonus
Reply 372 of 390, by matze79
this sounds like PC-Speaker only.
You need to PATCH Prince.exe for Tandy Sound.
EDIT:
Ah ok its POP2.. but it should also work. I had 3 Voice Sound with this Game.
Reply 373 of 390, by root42
matze79 wrote on 2020-03-02, 18:23:
https://youtu.be/l3cyuRbzKCM […]
EDIT:
Hm. I used PoP 1.3 with Tandy as music. Same for PoP2. But I also thought it sounded like PC speaker. I will try again!
YouTube and Bonus
Reply 374 of 390, by matze79
Yeah for Prince of Persia 1 you need to hexedit the EXE File..
Just unpack the EXE and Hexedit.
http://nerdlypleasures.blogspot.com/2015/08/p … sound-card.html
Reply 375 of 390, by matze79
Jan Knipperts bumped Version of Test Tandy Software
TEST TANDY v0.51
New Features
Version 0.51:
- MDA, Hercules Graphics
- Testsequenz / Test Sound
- Command Parameter
Testing Sequenze with -> /TEST <Port> -> TESTTNDY.EXE /TEST 1E0
Or Keypress F1
/K -> Keyboard Control (No Mouse)
/MDA -> Force Monochrome Mode
/COLOR -> Force Color Mode
/? -> Help
Maybe some day this will become a TANDY Tracker 😳
Reply 376 of 390, by root42
matze79 wrote on 2020-03-02, 21:43:
That concerns PoP 1.0. I was using version 1.3 which comes with a setup program to pick the sound card. I will investigate what Settings work... maybe they check for Tandy Bios and revert to PC speaker?
YouTube and Bonus
Reply 377 of 390, by matze79
Yes, i`m pretty sure it will do tandy checking.
Reply 378 of 390, by root42
matze79 wrote on 2020-03-03, 15:34:
Ok, then I will try again with PoP 1.0 and patch the binary.
YouTube and Bonus
Reply 379 of 390, by root42
I edited PRINCE.EXE from the 1.0 release, and at the given position changed the 75h to EBh. But no luck. I get Adlib only sound. Any ideas?
117.62 KiB
EDIT: "prince vga tandy" leads to sound, but it seems monophonic. could the PC beeper (which is attached to the TNDY card). "prince vga gblast" hangs the system, with the SnarkBarker (including SAA1099) installed.
YouTube and Bonus
