Bought this (Modern) hardware today
Reply 1000 of 2404, by Tertz
mothergoose729 wrote on 2020-02-12, 03:21:
Finally upgrading my PC after many years. Going Ryzen 5 3600 ... I do a lot of emulation, so I am excited for the extra threads […]
Ryzen 5 3600
I do a lot of emulation, so I am excited for the extra threads and increase in IPC.
DOSBox bench thread (check my signature) lacks newer Ryzen 3xxx to compare with previous 2xxx. Would be interesting to see the results for Ryzen's update there.
DOSBox CPU Benchmark
Yamaha YMF7x4 Guide
Reply 1001 of 2404, by mothergoose729
Tertz wrote on 2020-02-14, 18:41:
Ryzen 5 3600
Sure, I'll post there when I get up and running 😀.
Reply 1002 of 2404, by clueless1
After 5 years with a monitor I repaired that someone was going to throw out (it had a bad capacitor I replaced), I finally "splurged" and got me a modern 1080p monitor. My previous monitor was a 23" 1680x1050 Acer from 2007. I replaced it with this:
https://www.benq.com/en-us/monitor/stylish/gw2480.html
Still, a very economical choice. I just can't see spending more than $120 or so on a monitor for some reason. The benefits of more expensive monitors aren't as tangible to me. Not like a graphics card or a cpu, so it's lower on my upgrade totem pole.
Reply 1003 of 2404, by ruthan
I have got this, its real Matrox G200 for Windows 98 gaming, or some professional abomination?
The attachment 2020-02-28 22.59.09.jpg is no longer available
The attachment 2020-02-28 22.59.24.jpg is no longer available
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1004 of 2404, by imi
it's just four G200 on one pcb, one monitor each, so yeah, more for professional use, also it's quite retro actually ^^
Reply 1005 of 2404, by ruthan
I tried if its working, but im not sure that i have right cable, machine booted with this single videocard, but i got no picture, but i could remotely communicate with it.. i used DMS-59 cable, but im not really sure if it is right one.. its physically compatible.. but maybe these cards used some special version etc. Need just 1 G200 for testing, maybe if i cut card in 4 pieces if get one:)
Update: Found that there are MMS Win 98 drivers here: http://vogonsdrivers.com/getfile.php?fileid=596&menustate=0 😀
Reply 1006 of 2404, by imi
you need a LFH60 cable idk if it is a special one but there are many g200 mms specific cables for sale
Reply 1008 of 2404, by ruthan
imi wrote on 2020-02-29, 01:26:
DMS-59 is working at least for Dos - i have some with 2x DVI + i added DVI to VGA, only 1 of 4 possible (connector nearer to MB seems to primary one) outputs is working at the boot.
Reply 1009 of 2404, by imi
well that's good then, I wonder why they use different ones if the pinout is the same? ^^
Reply 1010 of 2404, by ruthan
Its 59 vs. 60 in name, i thing that i so +1 pin for performance or some company to make some buck..
Reply 1011 of 2404, by Srandista
Got one of the last non-SMR 4TB WD Red in state, to offload some data from my NAS. WD has replaced it (WD40EFRX) by "same" drive, but with SMR (WD40EFAX). Thanks, but no thanks.
Reply 1012 of 2404, by xjas
Snagged this more modern capture card for cheap for my streaming adventures. I don't need it to do anything fancy, as long as it can handle >=640x480 modes @ 60Hz it'll do the job. (This is a "1080p" card so I'm hoping it will also allow for 1600x1200, but I'll live if it doesn't.)
The attachment 20200402_231542.jpg is no longer available
The attachment 20200402_231633.jpg is no longer available
Note that those ports are one HDMI input and one "AV in." The card has a good selection of analog inputs using its wonderfully bizarre breakout cable - first time I've ever seen an HDMI connector repurposed for something decidedly not HDMI like that. What an odd choice!
I wonder if they had to pay the HDMI licensing fee for both ports...
Incidentally, I also tried to upgrade my glacial internet service yesterday... My mainland-based ISP were all set to give me a literal 10x improvement in upload & download speed for only an extra $10 per month, and roll in a cheap deal on a new DSL modem to handle it, until they looked up my address and figured out the basic plan I have was already maxing out the line capacity in my 60-year-old building. Guess I'm stuck with 6mbit/768k for the forseeable future. 😠 We're never going to get any broadband infrastructure upgrades in this area because the incredibly old NIMBY-ists who permeate all public discourse here are actively against it. Sometimes I hate this island.
Reply 1013 of 2404, by chrismeyer6
Xjax once Starlink is operational then you don't have to worry about it. I'm in a similar boat to you with my Verizon DSL service so starlink cant come fast enough.
Reply 1015 of 2404, by wirerogue
nos dell dimension xps gen 4.
it has pcie so we'll call this one modern.
not sure of the exact specs yet.
it was way too shiny for me to pass up.
can't wait to peel the plastic.
The attachment dell.xps.gen.4.jpg is no longer available
fresh bloatware
The attachment fresh.bloat.jpg is no longer available
Reply 1016 of 2404, by Srandista
That taskbar area is appalling...
Reply 1017 of 2404, by ODwilly
Bought a 1tb WD Black 750 NVME SSD for my main machine. The 250gb Samsung 860 Evo has been packed full for FAR to long, and now that I went Ryzen last month and received my 1st full paycheck today, it made sense to blow the money on a high capacity SSD. Also bought RDR2, so that should make for a fun game to compare HDD vs SSD since Im installing it on a 2012 Hitachi 2tb HDD right now.
Reply 1018 of 2404, by bjwil1991
Have fun, eh? I need to upgrade to a Ryzen and install nVME drives over the 480GB SSD, 1TB SSHD, and 1TB HDD. Might get a board that supports 3 of them and get a 1TB for the OS, and 2TB for the two 1TB drives for more storage.
Reply 1019 of 2404, by wiretap
Asus Maximus VIII Gene, under $65 shipped, supposedly new in open box. Been looking for one of these to use in a mATX case with the ROG Front Base Overclocking Panel. It should make a nice Windows 7/8.1/10 rig. Now I just need a CPU, RAM, and GPU. 🤣 edit: nevermind, found an i5 6500 and 8GB DDR4 in my spare parts so I can at least test the board when it arrives. Man, I totally forgot someone gave me a newer Dell that had that in it.. thought it was a 3rd gen i5 for some reason.
I mainly wanted to pick this up so I could have a fast Windows 7 system without having to hack up the OS for later update/driver support since Microsoft shafted us with the 7th gen+ chips.
My Github
Circuit Board Repair Manuals
