Reply 40 of 49, by Tiido
- l33t
BloodyCactus wrote on 2020-02-15, 22:09:IC376, IC404, IC405/EMU8000 ARE IDENTICAL CHIPS. IC376 is fabbed by AMI, IC404 is fabbed by OKI. IC405 has creative branding. They are the same chip!.
EMU8000 is definitely not same as IC404, the pinouts are very different and some functionality is also different. IC404 has native 68K CPU interface, completely different DAC interface and MIDI UART built in. EMU8000 only has 16bit access port and ROM/DRAM interface with i2s based sound input and output, but no UART and CPU control signal generation found in IC404, additional glue logic is necessary as seen on WBII (the PAL/GAL on it generates address decoding, interrupt response cycles and few other things). EMU8000 is made by variety of manufacturers, distinguished by the 3 letter code after CT1971. I have seen parts made by OKI, UMC and few other manufacturers.
