First post, by AeonG
I'm trying to build a PC that kind of bridges the gap between Windows 98 and Windows XP, allowing me to use both on it so I can test software and games before I upload them to an archive. I'm going to use a Pentium 4 processor, and for now I'm using an ATI Radeon 9250 (PCI version) card which works pretty well from everything I've thrown at it in the past. My new motherboard will have an AGP slot which I want to take advantage of, so before I get an AGP version of that card, I gotta ask, can I do better than this? What I want the most is a card that can support a very wide range of Win9x games, but also be able to test some XP compatible games from the early to mid 2000's, though that's less of a priority.
Reply 1 of 5, by kolderman
It's a difficult bridge to cross. WinXP means dx9, and cards with good dx9 support often lose compatibility with win98. I would say a geforce FX 5500 (fairly cheap), but it is not a strong performer. FX 5900 Ultra is better but expensive. You are better of with 2 PCs, one for 98 and one for XP.
Reply 2 of 5, by Joseph_Joestar
It really depends on how smooth you want your WinXP gaming experience to be.
If you're aiming for a locked 60 FPS at 1280x1024 then I'd say go for a separate XP system with a more powerful GPU and a faster CPU. But if you just want those early games to be playable at around 30 FPS and/or don't mind using lower resolutions like 800x600, then that Pentium4 and a GeForce4 Ti 4600 might be enough.
Reply 3 of 5, by The Serpent Rider
GeForce 5900XT. Cheap, fast, available.
Reply 4 of 5, by Ozzuneoj
What kind of sound card are you using? I recently was reminded of the issues with running Aureal Vortex cards with anything greater than DirectX 7.0a. Also had trouble exiting DOS boxes with an FX5500 in 98se with newer drivers and DX9. 0c. For a less problematic experience I definitely recommend using older stuff for Windows 9x.
Reply 5 of 5, by appiah4
GeForce 4 Ti4600 should do the job unless you need DX9 but that is really not early Windows XP stuff.
