Bitchin' Fast! 2D, (Video Loca, 1994, MCA)
First post, by Apolojuice
Does anybody remember this card?
IBM was working with Video Loca (later bought by Bitboys) to produce a video card that could run the XXXGA resolution at 4096x3072 at 42bit color depth at 69Hz, (2D > 3D), they were used briefly on CIA's IBM PS/2 Model 420 workstations that were responsible for scanning the American aerospace for early detection of foreign attacks, until they were decommissioned in August 2001.
I remember that this card had five GPUs on it, much like their later work with the Bitchin' Fast! 3D. And I remember thinking to myself that Matrox was the only manufacturer to make GPU for both the 2D and the 3D cards (I can't even remember the specific gpu used). I'm trying to put together a computer with 5 separate cards that has similar or same gpu core as the one used on the Bitchin' Fast! 2D, and I was wondering if anyone here could remember what the other four GPU's were.
Many thanks.
I only forget.
Reply 1 of 30, by cyclone3d
Bitchin' Fast! 3D was literally a joke ad.
There would have been absolutely 0 reason to have 5 different 2d cores on a single card.
On top of that, what would 42bit color depth be good for anyway? No displays would have even been able to use that.
https://en.wikipedia.org/wiki/Color_depth
The biggest hurdle back then would have been the amount of video RAM needed.
Resolution--------8bpc--------------10bpc------------12bpc------------16bpc-------------32bpc 1280x720-------2,7 MByte--------3, […]
1280x720-------2,7 MByte--------3,4 MByte-----4,1 MByte--------5,5 MByte------11,0 MByte
1920x1080-----6,2 MByte-------7,7 MByte------9,3 MByte-------12,4 MByte------14,8 MByte
4096x3072-----37,7 MByte-----47,2 MByte-----56,6 MByte-----75,5 MByte-----151,0 MByte
8192x6144----150,9 MByte----188,7 MByte---226,5 MByte---302,0 MByte---604,0 MByte
https://www.cgdirector.com/ram-video-editing/
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 30, by swaaye
Reply 4 of 30, by The Serpent Rider
This info is absolutely incorrect for displays.
Reply 5 of 30, by cyclone3d
The Serpent Rider wrote on 2020-02-25, 02:12:
What do you mean? I linked it because that is the amount of video needed for uncompressed frames at listed resolutions and color depth.
bpp is not the same as bpc
https://www.diyphotography.net/8-bit-vs-16-bi … th-use-matters/
YMF7x4 Guide
Reply 6 of 30, by The Serpent Rider
What do you mean?
You also need to include alpha channel. Which is, obviously, not a problem for uncompressed video frames.
Reply 7 of 30, by cyclone3d
The Serpent Rider wrote on 2020-02-25, 06:20:
What do you mean?
Ok, true. So what would the size be at 4096x3072 at different bpc including alpha channel?
YMF7x4 Guide
Reply 8 of 30, by Grzyb
cyclone3d wrote on 2020-02-24, 22:36:
Actually, with analog signal, every display is able to use that.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 9 of 30, by cyclone3d
Grzyb wrote on 2020-02-25, 07:07:
Yeah... Use it as in it would physically work.. but how many colors can the monitor actually display?
Most of the better ones later on were sold as supporting 16.7 million colors if memory serves.
The number of colors available for any X-bit image is just 2^X if X refers to the bits per pixel and 2^3X if X refers to the bits per channel.
so 42-bit depth - way over that. Looks like 48-bit color is about 481 trillion colors... So around 60 trillion for 42-bit color, right?
https://www.cambridgeincolour.com/tutorials/bit-depth.htm
And what interface would it have had to use at that bit depth and resolution.
See here:
http://monitorinsider.com/cable_bandwidth.html
Sounds to me like something like that would have been completely unusable over an analog vga type signal.
The technology for something to supports those crazy specs did not even exist back then.
Even now, the higher end LCD can't even support that much bandwidth... And video cards look to be limited to 12bpc or 36-bit color.. and that is at probably a max of 1080p.
From looking up stuff, consumer monitors are going to be 8bpc, higher end 10bpc, and 12bpc is very rare.
So yeah, 20+ years ago and this sort of thing was not anywhere near being possible.
YMF7x4 Guide
Reply 10 of 30, by H3nrik V!
True that!
But no person in the world would be able to distinguish it from 24-bit color 😀
But then again - if the spoof was to be true, the CIA computers probably could've used all that resolution to find details .. 😉
Reply 11 of 30, by The Serpent Rider
No idea. We don't even know how it would be divided on such card. 12bpc + 6bit alpha? 10bpc + 12bit alpha? Uneven bpc?
Reply 12 of 30, by Grzyb
cyclone3d wrote on 2020-02-25, 08:53:
Well, modern monitors, with digital inputs, indeed support precisely defined number of colors - eg. 16777216.
CRT monitors, however, usually claimed infinite number of colors.
Reply 13 of 30, by Garrett W
Did you guys seriously fall for this 😁?
Reply 14 of 30, by BinaryDemon
Im gonna stick with my IBM Bitchin’ Fast MDA card. The cursor blinks so fast it gives some people seizures.
Reply 15 of 30, by H3nrik V!
BinaryDemon wrote on 2020-02-25, 13:20:
Reply 17 of 30, by GrizzlyAdams
And I'm just smiling over here with my Bitchin' Fast! Audio card...
Reply 18 of 30, by Grzyb
GrizzlyAdams wrote on 2020-02-25, 15:34:
So, how fast it is?
If it can play the entire content of a 74-minute Compact Disk in less than 1 minute, then I want to buy that card as well!
Reply 19 of 30, by DNSDies
For real, an ¡AudioLoca! card featuring the best audio chips of all time would be cool.
Lets see:
SB Pro/16
Real OPL3 and OPL2
Gravis Ultrasound
Roland LAPC-1
Roland SC-55
What else can we throw in there?
Disney Sound Source?
A3D and EAX support?
