First post, by assasincz
HI all,
I am looking for an exact version identification and most importantly manual for mobo in the picture
Detailed pictures are here
https://photos.app.goo.gl/yCrdHzNB7yUAu3Dd7
Can you help me out, please?
Thanks
V.
HI all,
Thanks
V.
assasincz wrote on 2020-02-21, 19:55:Detailed pictures are here https://photos.app.goo.gl/yCrdHzNB7yUAu3Dd7 […]
https://photos.app.goo.gl/yCrdHzNB7yUAu3Dd7Can you help me out, please?
ThanksV.
It is a DTK PKM-0038S and appears to be a Ver 3 (definitely not a V6) but hard to tell if the jumpers are exactly the same from the poor picture.
Can you take a better picture of the whole board ?
The jumper settings to a V3 are here: https://stason.org/TULARC/pc/motherboards/D/D … 038S-VER-3.html
Horun wrote on 2020-02-22, 02:06:Can you take a better picture of the whole board ?
My mistake, full array of pictures in the link is now available,
I already got as far as stason.org, please notice that the RAM banks do not match (there are 4x30pin and 2x72pin), so this is not a correct manual
The rev1 of the same board has only 8 bit simm slots : https://stason.org/TULARC/pc/motherboards/D/D … S-VER-1-00.html
So you must have a rev2 board or something like that, which has no documentation it seems ... Or perhaps the scheme on th99 is wrong (this is also possible).
Deksor wrote on 2020-02-22, 11:19:The rev1 of the same board has only 8 bit simm slots : https://stason.org/TULARC/pc/motherboards/D/D … S-VER-1-00.html
Yes in TH99 one of the Asus boards has the wrong picture so possible that the Rev 1 board pic is wrong. In the real pictures it shows E-1A which could be Rev 1.A.
So, none of you have any solid lead on this mobo manual?
