First post, by markuno
Dear community, i would like your advise:
I have a setup consisting of a HP Vectra 500 with a 486DX4/100 in it. It already has a SBPro2 that works wonderful and I was thinking to buy and add a CT2330 SB16 to properly take advantage of the 16bit sound for the games with that option.
1) Do you think it makes sense this decision? I'be been reading various opinions to this subject.
2) In the affirmative case, which would be the correct way to a proper configuration daisy-chaining both cards?
3)Would be necessary/make any good the addition of a mixer?
4) I have already an AWE64Gold and a SC-55 that could use instead but that PC doesn't run very smooth fps like doom or heretic (forget about duke3d) so I think that goes for another project. This is mainly intended to cover adventures from early to mid 90s. Thanks in advance!
