First post, by Joseph_Joestar
So I noticed something interesting with this game. Aladdin has a number of different options in SETSND.EXE of which I've tried "Sound Blaster & AWE32", "Sound Blaster Pro" and finally "Windows Sound System". Testing those options on my Opti82c930 and Avance Logic ALS100 (not plus) with "Enhanced Music" turned on, I discovered the following:
  • Sound Blaster & AWE32 - the music plays back in mono on both cards, sound seems slightly muffled. Setup auto-detects High DMA = 5 for the ALS100 but it makes no difference in sound quality
  • Sound Blaster Pro - the music plays back in stereo on both cards, sound is clean
  • Windows Sound System - with the Opti card in WSS mode, the music plays back in stereo and possibly (not sure) sounds slightly clearer than with the SBPro option
This is very noticeable when using headphones and listening to the intro song "A whole New World". When the "Sound Blaster & AWE32" option is selected, sound is identical on both the left and right. However, in SBPro and WSS mode, you can clearly hear some instruments playing only on the left and others playing only on the right.
My question is, did this game not implement stereo on its "Sound Blaster and AWE32" setup option, or are my clone cards not supporting it? Can someone with a genuine SB16 or AWE32 test this? I'm also curious whether a genuine SB16 will play stereo music with the SBPro option selected.
My retro builds
Reply 1 of 53, by FreddyV
No, it can't, SB16 does not support SBPro Stereo
Reply 2 of 53, by Joseph_Joestar
FreddyV wrote on 2020-02-28, 10:32:
I know that too, which is why I asked for someone who has a genuine SB16 to test Aladdin with SBPro selected as a setup option and see if it plays stereo sound or not.
Or, failing that, if they can get stereo in any way on a SB16 in that game.
My retro builds
Reply 3 of 53, by digger
It's a shame that Aladdin didn't support the Gravis Ultrasound, given that the game used tracker music.
Reply 4 of 53, by dr_st
Looks like it's gonna be a while till I get to my AWE64 system to test on a real system.
What I can say is that in DOSBox, Aladdin plays stereo music with SBPro option selected, even if DOSBox itself has sbtype=sb16. But I don't know if DOSBox emulates a real SB16 in this regard.
Reply 5 of 53, by zyga64
From my observation. Game sounds much better on integrated YMF701 (intel TC430HX) - SoundBlaster Pro settings, than on Sounblaster Vibra 16s (CT2800) on the same motherboard.
It seems that this game has bug in SB16/AWE32 driver similiar to this in Jazz Jackrabit, or I just have bad version of a game...
8088@8 /640k /Genoa CGA /ALS100
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 6 of 53, by Joseph_Joestar
I'm finally back at my retro rig, so I'm uploading the intro song played back on my Avance Logic ALS100 using the SBAWE32 and the SBPro setup options.
When you listen to both recordings via headphones, the lack of stereo on the SBAWE32 setup option is easy to hear.
My retro builds
Reply 7 of 53, by Joseph_Joestar
Well, I now have a Sound Blaster AWE64 Value (CT4520). As expected, Aladdin does not play music in stereo on this card, regardless of whether I choose "Sound Blaster & AWE32" or "Sound Blaster Pro" in setup.
Conclusion: this is one of those few games where having a SBPro (or compatible) will give you proper stereo while having a SB16 (or AWE32/64) will not. So feel feee to use it for testing various cards for their SBPro compatibility.
I have also confirmed that WSS gives clearer stereo sound than a SBPro, and I can upload another MP3 for comparison if people are interested.
My retro builds
Reply 8 of 53, by firage
Good job documenting the bug. Good information to add to SB16/AWE's practical deficencies.
My big-red-switch 486
Reply 9 of 53, by Joseph_Joestar
firage wrote on 2020-06-24, 12:48:
Thanks! Looks like the old SBPro vs. SB16 debate is still far from over. I'm partial to WSS since it tends to offer the best of both worlds, when supported.
Speaking of which, I'm uploading the Windows Sound System version for the final comparison. It was recorded from an Opti 82c930 running in WSS mode.
My retro builds
Reply 10 of 53, by Gona
I have genuine SB Pro 2 (CT1600 Rev08) and SB16 (CT2230 Rev02) and I confirm that the SB16 is not fully SB Pro compatible. I have set the Aladdin to SB Pro and this on CT1600 sound in stereo:
The attachment Aladdin_SB_Pro_-_on_-_SB_Pro2_CT1600_rev08.ogg is no longer available
I have switched the card to the CT2230 and I have used an old and compatible driver for it (later drivers are less compatible), I have left Aladdin sound setup untouched (SB16 on the same PORT, IRQ and DMA as SB Pro 2) but the sound is mono:
The attachment Aladdin_SB_Pro_-_on_-_SB_16_CT2230_rev02.ogg is no longer available
Finally I set the Aladdin for "Sound Blaster & AWE32" and this is mono too.
Video card compatibility matrix for DOS games | ATI3DCIF compatibility matrix | CGL API compatibility matrix
Reply 11 of 53, by mothergoose729
On my Orpheus sound card WSS music never plays after the title screen. Sound blaster pro music is clean and stereo. In general, I have noticed that WSS sounds when mixed in 8 bit sounds similar to sound blaster pro 2, at least on my card, but slightly less filtered/cleaner.
Reply 12 of 53, by Joseph_Joestar
Gona wrote on 2021-05-16, 20:51:
Interesting, so we now have confirmation that this is the case with original Creative cards as well. It seems that Aladdin is indeed one of those rare games where a SBPro provides stereo sound while a SB16 does not.
mothergoose729 wrote on 2021-05-16, 20:53:
That's too bad. I have played through the entire game on my OPTi 82C930 and can confirm that all the songs play correctly in WSS mode. Looks like this might be another Orpheus WSS compatibility issue.
Do note that Aladdin needs quite a bit of free conventional memory for enhanced music (around 590 KB I think). If you have less than that amount, the music may not play correctly.
My retro builds
Reply 13 of 53, by mothergoose729
Joseph_Joestar wrote on 2021-05-16, 22:48:
Interesting, so we now have confirmation that this is the case with original Creative cards as well. It seems that Aladdin is in […]
It could be a configuration issue. I had to use eatxms to get around the no more than 32mb of availability issue that the game has. In general games after 1995 all work with a couple exceptions, but earlier WSS games usually don't. Fortunately the sound blaster pro driver is really good in that game.
Reply 14 of 53, by matcarfer
Interesting thread I must say. I recently played Aladdin on Genesis and sounded not that great, and always wondered how good could sound with differents Sound Cards, and never EVER head WSS with Aladdin till now, and man, it sounds fantastic. Guys, thanks for the audio uploads.
Reply 15 of 53, by Gona
I have found my Media Vision Pro Audio Spectrum 16 card so I have tested it too with Aladdin by set the "Pro Audio Spectrum 16". It is stereo, and sounds better than SB Pro2, it is close to WSS.
The attachment Aladdin_PAS16_-_on_-_PAS16.ogg is no longer available
Reply 16 of 53, by Joseph_Joestar
Gona wrote on 2021-05-18, 18:22:
Very interesting! Thanks for testing this, the PAS16 music sounds excellent to me.
I wonder why the developers did such a poor job with the SB16 option, when all the other cards deliver proper stereo music.
My retro builds
Reply 17 of 53, by Gona
Joseph_Joestar wrote on 2021-05-18, 19:26:
You are welcome.
Yes, interesting why only SB16 is poor mono. Might the 16-bit Sound Blaster options only a pretence/fake option and works full the same way as SB Pro option which in this case mono on SB16.
Reply 18 of 53, by Cloudschatze
Something is wrong with DSMI's SB16 detection routine in Aladdin. I can't speculate as to what. Here's a workaround config file though, concerning a SB16 configured with IRQ5 and high-DMA channel 5. (Byte 0x25 is the IRQ, and byte 0x26 is the DMA channel, if your SB16 is configured otherwise.)
Enjoy 16-bit @ 44.1kHz stereo output with your SB16, or something.
Reply 19 of 53, by Gona
Cloudschatze wrote on 2021-05-18, 20:40:
Wow! Great job!
The attachment Aladdin_SB16_(patched_by_Cloudschatze)_-_on_-_SB16_CT2230_rev02.ogg is no longer available
Is it also a detection problem when selecting SB Pro in Aladdin the SB16 works as mono?
