First post, by myki
Hello,
I tried to play with Bargon Attack with DosBOX v0.65, but i had a problem :
I needed to click to play animations.
I mean that if i release the mouse button, the animations stop.
I tried with a 0.60 version, and everything is fine.
MAybe this point of the changelog is the problem :
"Lockfree mouse mode added again"
I hope that it will help...
Mykael
Reply 1 of 2, by eL_PuSHeR
Did you try editting dosbox.conf and toggling the autolock= entry?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
well autolock shouldn't influence that part.
Water flows down the stream
