Reply 32860 of 58861, by brostenen
- l33t++
GigAHerZ wrote on 2020-03-05, 12:39:derSammler wrote on 2020-03-05, 12:10:Later, I was able to score a large lot of cheap NOS PS/2 mice based on the OM02 chip. These work on the Amiga by simply rewire them - you can even use the wheel as a 3rd button if you use a 9-wire cable.
Wait, just to make sure i have a correct understanding: The 9 pin connector for those amigas and ataris does not mean those mice are capable of being ordinary serial mice for old PCs?
Because if those are optical mice that support serial interface, then... i want to talk with you in ps! 😀
One of my friend's parents, had a 386 back in the days. And he plugged in an Amiga mouse. For some reason the COM-1 port died. I say for some reason, as I have no idea what actually dies and how and why. All I remembered, was that he plugged it in, ran the driver software and the port died. No magic smoke or any bang, it just went to the grave.
