First post, by mirh
So.. I hope I'm not doing the mother of all necroposting, but thanks to the Abandonia friends I found out still working links of the aforementioned Application Compatibility Toolkit patch.
You can find it here or here.
They are slightly different (as noted back in the day, it's still not clear what every single one of the fixes are needed for), but they should do the work.
pcgamingwiki.com
