Mortal Kombat Trilogy WinXP fix
First post, by mirh
Re: Mortal Kombat Trilogy
So.. I hope I'm not doing the mother of all necroposting, but thanks to the Abandonia friends I found out still working links of the aforementioned Application Compatibility Toolkit patch.
You can find it here or here.
They are slightly different (as noted back in the day, it's still not clear what every single one of the fixes are needed for), but they should do the work.
pcgamingwiki.com
Reply 1 of 3, by Stiletto
mirh wrote on 2020-03-07, 13:55:
You did. A topic from 2003? Split your reply into a new thread. Thanks for the fix tho.
do the Fandango!" - Queen
Stiletto
Reply 3 of 3, by mirh
Splitting threads just makes people finding the old one on google remain clueless.
.. I don't see the intrinsic problem with necroing if I'm actually completing the original discussion (rather than just "monkey asking for help").
EDIT: the message below this, on the other hand...
pcgamingwiki.com
