First post, by Baoran
Would it be possible to use this thing in a win98se pc that has a motherboard that only has usb header for usb 1.x?
If it works with the header are some kind of drivers needed for win98se?
1.31 MiB
Reply 1 of 2, by ragefury32
Eh, you can always add an NEC based USB 2.0 PCI controller board, install a USB2 stack (nusb33 or 36) for Win98SE and it'll work just *fine.
Otherwise, ehh...yeah, you could plug it to the USB 1.2 header and it "should" work, but....ooof, USB1 transfer speeds? Ain't nobody got time for that.
*Fine in Win98SE just means that you'll BSOD slightly more often due to the nature of that driver stack. But then it's freaking Win98SE anyways.
Reply 2 of 2, by Baoran
ragefury32 wrote on 2020-03-07, 16:26:
Main reason for using this would be to be able to use CF card storage in pure dos PC and to copy dos games to a CF card using this. Dos games are not that big that I would be worried about the transfer speeds as long as I get it to work in a pc that has optical drive since I keep copies of my dos games burned on optical disks.
