First post, by wpegden
I'm trying to install x-wing from the 5 original disks. First I do
mount /dev/fd0 /mnt/floppy
in linux. Then in dosbox, I mount A: as
mount a /mnt/floppy -t floppy
once the install program asks for disk 2 (insert disk 2 and press a key, etc), I unmount /mnt/floppy in a linux terminal, remove disk 1, insert disk 2, and then do mount /dev/fd0 /mnt/floppy
I hit a key in the dosbox window, but the installation program just beeps and tells me to insert disk 2. The funny thing is that once I close the installation program, I can hit dir and Dosbox knows the disks have been swapped. What could be going on here?
Thanks,
Wes
