First post, by GL1zdA
- Oldbie
I have a PC with an AWE32 card (actually the goldfinch upgrade for an on-board Vibra). When I run the Descent setup utility in the Windows 95 DOS box, I can't find a way to configure the AWE32 for music, it will just fail with "driver not found". On the other hand if I "Restart in DOS mode" everything works: the setup utility can use the AWE32 and it works in game.
Is there any way to make the "DOS box" aware of the AWE32?
