First post, by lutz79
Hello guys! I need your help!
I have a 486DX4-100 without a serial port, and i can't use any mouse because the motherboard don't have any ps/2 ports, but only COM1 and COM2 connectors with 10 pins.
I have purchased this one from Amazon: https://www.amazon.it/gp/product/B001Y1F0HW/r … 0?ie=UTF8&psc=1
The problem is that the driver (mouse.sys and mouse.com) dont' work. Obtain the error message "mouse not found". I have tried different drivers, but the problem is the same. In the BIOS setup, both com1 and com2 are enables. On my 8088, also without mouse connected, the driver works regularly (with com1 integrated on motherboard).
I believe that the serial connectors are all the same, but I'm not sure. In your opinion, could there be incompatibility issues with an XT motherboard? how could I solve the problem?
Thanks!
