First post, by Tiemen
I'm building a xp machine.
Specs
Gigabyte GA-H61M-S1 REV 2.1
Gtx 750
2X 2 GB 1333
I3-2130
I have two of these motherboards, the other one works with the same specs. It only is Rev 3.0 instead of 2.1.
What happens: it starts up, I get the startup screen, in which I should press buttons. None of the keys responds. I've tried ps2 and USB. After 2 minutes the screen goes black, while still running. Gpu is fine.
Is my motherboard defect or am I missing something?
Thanks in advance!
Reply 1 of 2, by PTherapist
Try removing the battery to clear the BIOS settings and see if it makes any difference.
Failing that, try with everything disconnected except for the ATX & 4-pin power cables and connect a monitor to the onboard graphics and see if you can get any further. Maybe also try different RAM sticks.
Reply 2 of 2, by Tiemen
PTherapist wrote on 2020-03-17, 17:23:
Thanks. Already replaced cmos battery, and tried two working cpus and 4 ram sticks. Did everything else also. Stays the same.
