Reply 14540 of 27685, by vmr_
Today I spent my time looking at these beauties 😀
Soon will put it to the test...
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 14541 of 27685, by LewisRaz
I dont have a PS/2 port 🙁
My mouse is serial. I have tried it in 2 machines and same behaviour (with the drivers you posted thankyou)
My retro pc youtube channel
Twitter
Reply 14542 of 27685, by bjwil1991
It could be the IC chip that controls it or the switch is bad.
Reply 14543 of 27685, by Bruninho
While Rio de Janeiro is under quarantine thanks to COVID-19, I had my last day of home office on friday and now I am starting a three week vacation... at home. My boss didn't want to postpone my vacations so I could have a nice trip to Spain rescheduled for when the world comes back from the virus spread... I'm pissed... Time to look elsewhere for a new job with a better boss.
Meanwhile, I fired up my Windows 2000 VM and played some matches with Fifa 99. =)
JOBS, Steve.
Reply 14544 of 27685, by EvieSigma
I tried out the new DOS version of HWINFO on my 386 and 486 towers, as well as trying to get the 386 to boot off its hard disk. For some reason despite having the right drive parameters and the hard drive being recognized by HWINFO (it's a Seagate ST3144A, 131MB IDE drive) I would get a "HDD Controller Failure" after putting the parameters in and a DOS 6.22 boot disk couldn't find the hard drive.
Reply 14545 of 27685, by bjwil1991
Does your 386 retain the settings after saving them in the BIOS? If not, change the clock battery with an external.
Reply 14546 of 27685, by Horun
EvieSigma wrote on 2020-03-22, 01:45:
Some drives (like your Seagate) have native and translated C-H-S. Your tried: 1001-15-17 ?
Reply 14547 of 27685, by EvieSigma
Horun wrote on 2020-03-22, 01:57:
1001 cylinders, 15 heads, 17 sectors? That's what I put in, going off this website here.
https://www.computerhope.com/hdseagat.htm
Reply 14548 of 27685, by Horun
Yeah it matches the docu by seagate: ftp://ftp.seagate.com/techsuppt/at/st3144a.txt
Does your BIOS also have Precomp and Landing Zone in the HD setting ? Some HDD just do not work well with certain older BIOS. I have a board that a 200Mb works, a 540Mb works but a 320Mb does not like that board....edit: meant 320Mb
Reply 14549 of 27685, by EvieSigma
Horun wrote on 2020-03-22, 02:07:
Yeah, it does. I put in 0 for both because that link I have doesn't give a value for those.
This is the hard drive the computer came with so I presume it worked in the past.
Reply 14550 of 27685, by bjwil1991
Does the BIOS save the settings? Also, check the jumpers on the hard drive and make sure it's not set to AT mode and make sure it's set to single drive (master) mode.
Reply 14551 of 27685, by EvieSigma
bjwil1991 wrote on 2020-03-22, 02:26:
HWINFO reports the drive as being in IDE mode but doesn't mention whether it's set as master. I'll have to check that the old fashioned way.
Reply 14552 of 27685, by Horun
Playing with a Vtech Laser XT/3. The machine came with 640k+512k expanded, a VTCL VGA card and standard VTCL I/O card with 720k 3.5" and 360K 5.25" drives. Plus a DataCannon SCSI adapter (way better than the crappy original RLL card imho) but the Seagate 80Mb SCSI was dead. Installed a 200MB WD SCSI and works well so far. Still need to fix the PSU but am thinking of just swapping in a newer AT PSU board since the paddle switch is a true switch and not some odd lever action thing. Some pics..
    646.01 KiB
    167.74 KiB
    272.96 KiB
    359.17 KiB
    304.15 KiB
Reply 14553 of 27685, by Horun
A pic of the front and PSU
    247.56 KiB
    208.07 KiB
Reply 14554 of 27685, by bjwil1991
Ran a patch to Space Quest 1 and 2 for the blond hair on Roger Wilko using my Core2Duo laptop, Raspberry Pi 3B (DHCP server), and a network switch. I then shared the Games directory and the floppy A drive so that I can copy the files in the SQ1 and SQ2 patch directories to the SQ1 and SQ2 directories in the Games folder, installed Visual C++ Redistribution 2010 both x86 and x64 so that the one program could run. It was quick and painless and it looks pretty cool.
Reddit: https://www.reddit.com/r/Sierra/comments/fmfc … _i_and_ii_mods/
Reply 14555 of 27685, by Predator99
I recently bought this Voodoo 3 PCI as part of a scrap lot...was actually the reason to buy. I was rather disappointed as I saw that the card was in a disastrous condition. Difficult to see on the photos, but it was totally bend and did not even fit in the PCI-slot anymore. 2 Caps missing but this is a minor problem.
I bent it straight again and gave it a try. Totally surprised that the cards powers up and works in text mode without problems. In graphics mode there are some minor display errors most likely caused by bad RAM. Maybe it will be fixed after addiding the missing caps.
1.53 MiB
412.82 KiB
1.13 MiB
705.46 KiB
Reply 14556 of 27685, by Munx
Predator99 wrote on 2020-03-22, 08:49:
I can spot 4:
C10
C49
C140
C129
My builds!
The Underdog - The budget K6
Reply 14557 of 27685, by Predator99
You are right...C129...didnt see that.
Thanks!
Maybe the reason for the RAM-problem.
Anybody know the value..?
For C10 I dont think its required. If you take a look on other cards its not popoulated there too.
Reply 14558 of 27685, by Predator99
Predator99 wrote on 2020-03-22, 09:30:
You are right...C129...didnt see that. Thanks! […]
Thanks!
C129 also not required, see here:
http://www.vgamuseum.info/index.php/cpu/item/ … x-voodoo-3-2000
Reply 14559 of 27685, by andrea
Thanks!
On my V3 3500 all the caps of that size are 10uf 16v. But I think, for testing purposes, as long as something is there it should be fine. If the screen corruption persists, check the legs of the ram chips for bad joints, especially since the card is bent.
