First post, by bloodem
- Oldbie
Hello,
Does anyone have this board either working with this multiplier/voltage combination or a newer manual revision for it?
The manual that I have lists the 2.1V setting as being the lowest and 3X multiplier as being the highest. However, I've seen on 20 year old forum threads that higher multipliers/lower voltages are indeed possible.
I have another SS7 board (Azza PT-5VMD), and that one has a very comprehensive manual, listing voltages down to 1.6V and up to 6x multipliers.
In case you are wondering, I want to run an AMD K6-2+ 550MHz CPU on the DFI P5BV3+ board. This CPU runs at 2.0V (however I tested and it can run as high as 2.2V). But I would prefer to keep it on 2.0V, to keep the heat levels down.
Thanks,
Andy
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
