Reply 33141 of 53082, by imi
- l33t
an early TUF concept? x3
Reply 33142 of 53082, by kolderman
Probably part of the case it was in. Can you unscrew it?
Reply 33143 of 53082, by bjwil1991
- l33t
I don't know what it is, but I dig those Socket 423 boards. I have one that has 768MB RDRAM (requires all 4 to be filled, or 2 filled with 2 terminators, much like SCSI cables requiring those termination ends to allow the drives to be recognized).
Reply 33144 of 53082, by wirerogue
- Member
did a little research.
the hsf retention mechanism is connected to the metal plate.
according to anandtech, it was part of a new atx 2.03 case spec where the hsf retention mechanism would mount directly to the case https://www.anandtech.com/show/764/3
the back plate is then optional if your case is not compliant with this new spec.
i've seen these 4 holes in a few cases (photo below) but, they are rotated 90 degrees and higher up.
it looks like asus just said f*** you guys, we'll put it wherever we want and make you use this giant plate instead.
so... not optional.
Reply 33145 of 53082, by piatd
- Newbie
appiah4 wrote on 2020-03-23, 08:08:It happens to pretty much everything I buy hereabouts, I just give them a good rub with de-ox/contact cleaner spray.
What do you use, exactly?
Reply 33146 of 53082, by Vegge
- Member
Very slow with purchases here.
Got this yesterday, slotket with p3 800. Slotkets are always good to have around.
Then something wierd. I have a bookshelf in my computer-room, and just in passing I saw this and pulled it out. I have no idea when I got it or where. Can't remember it at all. Makes me wonder if I have other unknown treasures hiding in my room. 😁
A nice Chaintech 486SPM. Support for, 3.3V CPUs, 128mb ram and 1024k cache. I have still to check if it works, my bench is full of other stuff atm. And it looks brand new, no signs of being mounted.
Reply 33147 of 53082, by SilverHawk
A package arrived for me today. https://www.ebay.com/itm/Lot-of-23-Working-CP … =p2047675.l2557 Should keep me busy for awhile.
Reply 33148 of 53082, by H3nrik V!
- Oldbie
SilverHawk wrote on 2020-03-25, 21:59:A package arrived for me today. https://www.ebay.com/itm/Lot-of-23-Working-CP … =p2047675.l2557 Should keep me busy for awhile.
Very nice lot - a and veeeery nice price, too .. Congrats!
Reply 33149 of 53082, by luckybob
- l33t
@wirerogue
Asus did this with several boards from that era. My XG-DLS has a similar plate, and its whole purpose in life is to properly mount the heatsinks for those 2 massive slot-2 heatsinks.
The plate is 100% required, unless you can get the proper stand-offs on your case to support the cpu heatsinks.
Reply 33150 of 53082, by EvieSigma
That's a nice lot! Assuming you can find a Super Socket 7 board (hell, if you can't, I have one I'd part with if you don't mind AT), you can do a lot of fun experiments comparing your various Socket 7 CPUs.
Reply 33151 of 53082, by imi
- l33t
$55? wow that is nice indeed, congrats :3
those lots sell for soooo much more here unfortunately... even if it's just scrap CPUs.
Reply 33152 of 53082, by Artex
- l33t
vmr_ wrote on 2020-03-23, 22:09:Will just go with this one, no words required to describe it 😀
WANT!! Nice score!
Reply 33153 of 53082, by SilverHawk
EvieSigma wrote on 2020-03-25, 22:35:SilverHawk wrote on 2020-03-25, 21:59:A package arrived for me today. https://www.ebay.com/itm/Lot-of-23-Working-CP … =p2047675.l2557 Should keep me busy for awhile.
Thank you, I feel lucky getting this lot. The Shuttle Hot-569 was the closest I ever got to owning an SS7 board. No 100Mhz front side, but I was able to get a decent overclock on my Pentium 200. My brother had FIC VA-503 board, but I never made the jump as I had paid a premium for the 569. I saved my pennies before ultimately getting on the AMD bandwagon with Socket A. Good times!
Thanks for the offer on the SS7! For now, I have a couple of Socket 7 boards to play with. An Asus VX97 machine I saved from the scrap pile and I dug out the motherboard from the first machine I built. A PCChips M575 with the "TXPro" chipset. That said, don't be surprised if you get a PM from me. 😀
Reply 33154 of 53082, by vmr_
Artex wrote on 2020-03-25, 23:51:vmr_ wrote on 2020-03-23, 22:09:Will just go with this one, no words required to describe it 😀
WANT!! Nice score!
This one deserves a place on any respectable WTB list. Took me nearly 2 years to find it 😀
btw, nice collection you have
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 33155 of 53082, by EvieSigma
I got two computers in yesterday but didn't get a chance to take pictures of them until today. I posted about them in here before but I figure people would like pics! The Compaq Presario 850 turned out to be a 486DX2-50 just like I expected, and just like I feared the power supply is stone dead. Probing a 4pin Molex drive connector resulted in 0.00V on both the 5V and 12V lines. And this is a weird proprietary PSU with non-standard AT power connectors so I guess I have to attempt to fix it...
Reply 33156 of 53082, by EvieSigma
I also got the eMachines eTower 366c in the same day, this one's a much happier story. Booted right up the first try without any issue, aside from a dead CMOS battery. I just need to throw in a hard drive and install an OS.
Reply 33157 of 53082, by mastergamma12
- Member
EvieSigma wrote on 2020-03-26, 22:23:I also got the eMachines eTower 366c in the same day, this one's a much happier story. Booted right up the first try without any […]
Nice to see a Cyrix rig.
Reply 33158 of 53082, by EvieSigma
mastergamma12 wrote on 2020-03-27, 00:17:EvieSigma wrote on 2020-03-26, 22:23:I also got the eMachines eTower 366c in the same day, this one's a much happier story. Booted right up the first try without any […]
Believe it or not, this is the first time I've been able to find a full Cyrix system that wasn't being sold by an overly optimistic eBay seller with a $200 price tag.
Reply 33159 of 53082, by x0zm_
Another card I've been after for awhile to the GPU collection!
Though I've been moving away from this era lately, the opportunity to snag another Triplex card couldn't be left untouched. It joins the GeForce3 Ti and GeForce2 - the Triplex Millennium Silver GeForce4 MX440 Dual Head!
