First post, by pan069
- Oldbie
I have an Asus 486 PVI SP3 motherboard and it has a PS/2 mouse header. However, it didn't came with a PS/2 mouse bracket. So, looking through my parts bin I came across two PS/2 mouse brackets. One of them has a 5 pin connector and won't fit the header on this board (I could make an adapter but I don't have the time for it at the moment). However, the other bracket has this weirdo connector. The board expects the 2x4 pin layout but this connector has a keyed 2x9 connector (see photo). It looks like they just grabbed what was available in the factory or something...
With the machine turned off, the connector does seem to fit (one way, flipped around the unused part of the PS/2 corrector is blocked by the keyboard connector).
Now my questions is; since the PS/2 connector has a 5v connection. Can I safely test this if it was connected the wrong way round? I don't have access to a multi-meter atm.
