First post, by RetroLizard
Hello again, everyone. RetroLizard here, looking for suggestions on which network card (IPX/Modem) to go with for MS-DOS 6.22, and some tips on getting IPX configured correctly.
Reply 1 of 17, by dionb
Usually something 3Com or SMC-ish, but what the best is rather depends on what bus(es) you have. 8b ISA, 16b ISA, EISA, MCA, VLB or PCI all have their own best options. In general, use the widest/fastest bus available.
Reply 2 of 17, by RetroLizard
I have two boards, both with PCI, and one with two ISA slots.
Board with the ISA slots is a P(entium)2/3/Celeron machine, so I'm guessing 16-bit ISA?
Reply 3 of 17, by dionb
Why? 16b ISA is far slower than PCI.
Reply 4 of 17, by RetroLizard
How do I tell what type of ISA slots I have?
Reply 5 of 17, by dionb
Again, why bother if you have PCI? But how to tell: look at them, you can see instantly if it's 8b or 16b. Look up any Wiki article for the visible differences.
It would help of course if you'd share the exact names of the motherboards with us.
Reply 6 of 17, by RetroLizard
Only board I have with ISA slots is a GA-6BA
Reply 7 of 17, by dionb
Look, I've said three times already that PCI is a better choice than ISA if you have it, but you keep on going on and on about ISA... If you don't follow advice and don't say why not I can't help you.
Reply 11 of 17, by mdog69
RetroLizard wrote on 2020-04-13, 06:53:
mdog69 wrote on 2020-04-13, 06:41:
Whereabouts in the world are you?
In the west side of the US.
Ok - just asking in case someone closer had a card spare.
As far as I know the 3C509/509B and NE2000 cards were as close as you could get to a standard card.
Reply 12 of 17, by RetroLizard
I think it might be possible to have two network cards available in a computer - One for MS-DOS games (Like Doom, or any games from the time period that supported IPX) and one for games from 1996-2000?
Reply 13 of 17, by aha2940
RetroLizard wrote on 2020-04-13, 07:21:
That should work, but I don't see a reason to do that. Any old game should work fine with a 10Mbps card...
Reply 14 of 17, by Intel486dx33
When I took Novell certification courses they recommended the 3com Earthlink lll 3c509 card or an NE2000 Novell certified card.
Reply 15 of 17, by dionb
Intel486dx33 wrote on 2020-04-14, 08:46:
Is that the intergalactic version of the Etherlink III?
Reply 16 of 17, by Intel486dx33
That's the hardest part about setting up a Novell client or server is getting compatible network cards. You can't go wrong with the 3com 3c509.
it's probably the most versatile network card ever. I use the ISA versions 3c509B or C
In PCI I think they have the TX model.
But it will save you allot of head aches to get a compatible network card.
Reply 17 of 17, by RetroLizard
Intel486dx33 wrote on 2020-04-14, 11:56:
Isn't that true for pretty much all old hardware?
