Reply 33400 of 52976, by liqmat
brassicGamer wrote on 2020-04-14, 15:00:
DPT PM2122 EISA SCSI controller with CM4000 cache module. […]
Plus, something I didn't know until just now, it has one of those freaking awesome strobing LED blocks! Can't wait to bench this against VLB and ISA caching controllers...
Nice! Here is everything you need for that card >> ftp://ftp.dyu.edu.tw/pub/Hardware/stuff/scsi_card/DPT/SCIII/
I have an earlier model (PM2012B/90) and it's still crunching data to this day.
679.9 KiB
Edit: I also archived the original driver disk (SmartCache Utilities) for the PM2012B/90 over @ -0° >> http://minuszerodegrees.net/manuals.htm#DPT
Reply 33401 of 52976, by dionb
Made a big-ish haul for the first time in ages today. Nothing truly spectacular, but a lot of nice stuff - piles of small IDE HDDs, some SCSI HDD and CDRoms (including low-profile) and some interesting motherboards, including an SE440BX with Yamaha sound. Pics on their way later this evening 😀
Reply 33402 of 52976, by imi
dionb wrote on 2020-04-14, 16:00:
nice :3
so far I only had a Chaintech 440LX board with YMF740C and an Intel AL440LX with OPL3/OPL4
but I got a Dell with a broken case recently that is still on its way with an Intel 440BX board in it as far as I can tell that should have a YMF724F
edit: the Intel DELL OEM board seems to be pretty much the same board as the SE440BX but with 5x PCI and 1x ISA
Reply 33403 of 52976, by King_Corduroy
Man Jealous of the cassette player! I almost bought a Phillips one like that but I didn't for some dumb reason and now I'm kicking myself cause it's hard to find those top loading 70's units. 🤣
Check me out at Transcendental Airwaves on Youtube! Fast-food sucks!
Reply 33404 of 52976, by dionb
imi wrote on 2020-04-14, 16:44:
nice :3 so far I only had a Chaintech 440LX board with YMF740C and an Intel AL440LX with OPL3/OPL4 but I got a Dell with a brok […]
nice :3
This one's a Dell board too. Not sure if it has regular ATX or weird Dell PSU pinout. Doesn't really matter though as I found the matching PSU in the lot too 😀
Remarkably, it's not the strangest pinout. A Compaq i810 board takes that prize - it has a 24p power connector from way before it became hip (and standardized). I don't like i810, but this is about as good as they come: 4MB video memory onboard, and 3 ISA slots thanks to an ITE bridge chip. Also have the PSU for this.
Reply 33405 of 52976, by LewisRaz
Saw a PC come up on FB market that caught my eye. Unfortunately it was 1hour away so I wouldnt be able to get it during these times..
I also was looking on ebay and noticed the same PC and saw postage offered so hit the buy it now 😀
I attached some of the sellers pics.
The listing is for:
AMD K6-3 400mhz CPU
64mb RAM (2x 32mb simms!)
IDE1 6gb
IDE2 33gb
Labway ISA Soundcard with genuine Yamaha chip
S3 Virge DX PCI graphics
PCI USB hub
Netgear Ethernet NIC PCI
3Com Dialup ISA card
Nice beige desktop case with ATX form factor and another ISA soundcard for the collection.
Look forward to playing around with this one.
    163.07 KiB
    266.55 KiB
    179.51 KiB
My retro pc youtube channel
Twitter
Reply 33406 of 52976, by imi
very nice, my PC pickups are somehow never this clean x3
dionb wrote on 2020-04-14, 17:33:
oh yeah, it has the weird dell pinout probably with an extra aux plug, not sure if I trust the old Dell PSU though, depends on how broken the case arrives (side panel is plastic), maybe I'll keep it stock after all.
Reply 33407 of 52976, by dionb
Right, here's the pic:
332.36 KiB
This is actually less than half the haul,but I'm taking the rest to be recycled - a mix of badly battered optical and floppy drives, two PSUs so light the "300W" on the side is pure fantasy and a pile of non-PC related cables. And a completely bent car radio 😉
So, what did I keep? The highlights:
- Dell/Intel SE440BX with Dell pinout, but nice YMF724F and SBLink if that's not enough. Oh, and a P2-450.
- matching 250W PSU. Pretty battered though so needs good inspection before testing.
- nice little Asus CU4VX-CM with universal AGP and onboard SB64PCI (no ISA or SBLink though).
- beautiful if underwhelming Diamond Stealth II G460, i.e. i740.
- two FSP 250W PSUs. Big, HEAVY beasts, my favourite period-correct PSUs if their caps are still good.
- a pile of 12 850MB-6.4GB IDE HDDs.
- a 1GB Fujitsu SCSI HDD.
- a low-profile Toshiba SCSI CDRom drive.
I'm particularly happy with the last two. I want to get an EISA system working and only have SCSI controllers. My only available SCSI drive smaller than 8GB was 20MB. Also, I've been struggling to get Solaris installed on my SparcStation 20. Sun OpenBoot is notoriously picky about booting from CD and I suspect my only other working SCSI player is the problem. This low profile drive has IBM part numbers on it, but I know I was able to boot my previous SS20 from exactly this model 15 years ago, so I am optimistic now.
Reply 33409 of 52976, by Horun
dionb wrote on 2020-04-14, 19:55:
So, what did I keep? The highlights: - Dell/Intel SE440BX with Dell pinout, but nice YMF724F and SBLink if that's not enough. Oh […]
Holy Guacamole Batman ! Nice haul ! You can send me the HD's and motherboards, my birthday was two days ago 😁 Would be a fantastic B'day present ;D
Reply 33410 of 52976, by Thermalwrong
Someone keeps selling old PC parts in the UK and he's finally started selling some of his broken stuff. I put in an offer for this nice Soyo 025R2 motherboard - I've now got too many VLB 486 boards, but this one is from 95/96 and has a voltage regulator. It's also got the ideal port layout for the case I plan to use it in.
Here it is before repair:
1.73 MiB
And after, fixed by desoldering the AT power connector & keyboard connector, repairing some of the traces, putting it all back. One of the 72pin memory slots doesn't want to work, but one working slot is fine. The BIOS battery is replaced with a coin cell by cutting the power trace to the diode that would normally charge the NIMH battery.
1.13 MiB
All up and running - nice board! It supports LBA so it's happy to use drives up to 2gb
1.44 MiB
Reply 33411 of 52976, by pentiumspeed
Exact same motherboard from Dell, but mine seems not to start up with PII fsb 66 CPUs but will start up with PIII 100 fsb cpus.
Cheers,
Great Northern aka Canada.
Reply 33412 of 52976, by bjwil1991
Thermalwrong wrote on 2020-04-14, 23:10:
Tremendous motherboard repair. I have a board that had more damage than I thought and no parts available, plus, some of the other items were completely done for and all 4 SIMM-72 slots were damaged.
I ended up buying a board that I remember that was in the family computer from 1994-2012 until the BIOS chip gave up the ghost and replaced the 1 small flaw: the CPU lever arm by taking the lever off of the broken board and placed it onto the M912 V1.7 board with success. I need to upgrade the CPU to a higher speed (might get a DX4-120 since that was in the board I had a long time ago, but sold the CPU long ago and the old video card I had that was a Western Digital Bahamas Paradise 64 with an S3 Vision 864 or S3 Trio64, which was a great Windows and DOS GPU, stopped working as well).
Reply 33413 of 52976, by pentiumspeed
Thermalwrong, You have a PM I sent awhile ago regarding making more W1D belts. I have two compaq notebooks needs these.
Secondly,
The board you fixed, what is this VLB video card, this one with large number of memory chips?
Cheers,
Reply 33415 of 52976, by Jed118
pentiumspeed wrote on 2020-04-15, 00:05:
Thermalwrong, You have a PM I sent awhile ago regarding making more W1D belts. I have two compaq notebooks needs these. […]
Secondly,
Cheers,
What kind of Compaq notebooks? I might need one belt too!
What's for sale? my eBay!
Reply 33416 of 52976, by Jed118
Bondi wrote on 2020-04-14, 08:56:
Bought this Hitachi docking station for Visionbook Pro series laptops. Label says for 7000/8000 series, but it works fine with my 6000 series laptop. The key features why it's of any value for me is the game port and the line-in connector.
Here are the pics.
Gravis gamepad for scale?
I love these pads!
Reply 33417 of 52976, by Cyrix200+
Daniël Oosterhuis wrote on 2020-04-11, 12:45:
Bought and received this board a few days ago, forgot to post about it. It's an Austin Computer Systems 33VL 386DX board, that I […]
Bought and received this board a few days ago, forgot to post about it. It's an Austin Computer Systems 33VL 386DX board, that I got for €25. Very good price, but it does have some work cut out for me. It's clearly been stored in a box full of other things or something like that, given it's fairly dinged up. Some of the SIMM slots have bent pins, but seemingly not bad enough to short or not make contact at all. One SIMM slot is really shot, and probably needs replacing. One ISA slot's a bit bent, and another few have pins that are slightly pushed back, but that probably can be massaged back into place. The board has a chipped off corner, and some top layer chipping next to the ISA slots, but both of these spots don't have traces or components on them, so it's not too bad. I might get some UV soldermask to cover it up, to prevent further chipping.
The Dallas RTC (very Texan thing going on here) has already been desoldered and I already have an idea how to mount the CR2032 to it, which I'll post later. The chipset QFP pins are all fine, and despite some scuffing and scratching, no traces appear to be damaged. Could be much, much worse, this board has had some luck getting damaged where it doesn't matter too much, or can be relatively easily fixed. Online resources say this board will work with 33MHz and 40MHz 386DX chips, so an Am386DX40 is on my way from China. Just need to find a good VGA card, sound card, NIC, a good amount of memory, and maybe a 387 to go with it, to build a nice 386 rig.
There were two nice AT systems with good early 90s cases for such a build at my internship, but sadly I won't be going there for a while due to the COVID-19 situation. Hopefully those will still be there, and I'll be allowed to take those away, as they're in the storage room with a pile of other systems that were taken from clients when the company upgraded their systems. One is still its original color, the other one's been painted black. I did do a quick test of the black one, and that had a Pentium Socket 7 system of some kind. I do hope my boss won't do a clean up of those while I'm gone!
z5dwbyF.jpg?1Q9OlaPf.jpg?1iUnx507.jpg?1mvDVMpM.jpg?1
Happy to see that board went to a fellow Vogon-er. I also considered a bid but decided I have enough projects for now 😀
I hope you can fix the memory slot(s). Maybe a transplant from bank 1? The seller told me the ISA slot accepts cards (they still fit in the slot), but it does look bent a lot.
Succes!
1982 to 2001
Reply 33418 of 52976, by dionb
Cyrix200+ wrote on 2020-04-15, 07:10:
Succes!
Speaking of things which should go to a fellow Vogon - there's a dead ITB 386 on MP at the moment. Bad pics of course, but at the very least it has a leaking battery. Apart from that it's a nice AT case, unremarkable 16b ISA multi-IO and what looks like a Trident ISA card. But one thing that is clear in the pic: a shiny MR-BIOS sticker.
I'm out of spare cash and time for at least the next week, but that thing needs picking up by someone who can rescue that BIOS. And it would just be a 20min drive for you 😉
Reply 33419 of 52976, by Daniël Oosterhuis
Succes!
Yeah, I was thinking about pulling the good pins from the damaged slot for the bent ones on the otherwise intact ones. I did just remember I have a dead Macintosh Classic II board somewhere, likely still with a pair of 30 pin SIMM connectors on it... That will be good to replace the damaged slot with, if I can find it 😀
The ISA slot does indeed still accept a card, with a little bit of force, and the pins do seem to make contact. I did already bend it slightly back into shape, so it'll be fine. I'm just waiting for the CPU to come in so I can at least verify it POSTs, then I'll see about a VGA card, XT-IDE (just for the ROM), a good I/O card, cache, RAM, case, etc. Will hopefully make a nice 386DX40 system in the not too distant future 😀
