First post, by Kronuz
I modified DOSBox so that it can unmount CD images. I also fixed some bugs on my way. Here's the patch.
Please let me know how it goes for you.
    dosbox-cdunmount-20060531.diff
    11.55 KiB
    234 downloads
    CD Images unmount
Kronuz
"Time is of the essence"
Reply 2 of 9, by Kronuz
It still has a bug, as you know CD-ROM drives must be one after the other, right now you can't mount drives that break the order, however right now you can still unmount drives in the middle; in other words, you can always unmount images.
Other bug I missed in the first patch is, when you unmount cdrom drives that were mounted from a directory (not an iso file) the drive letter is not freed. I already fixed that, I'll attach a patch.
* Uploaded a small fix in this patch
    dosbox-cdunmount-20060531b.diff
    12.47 KiB
    220 downloads
    New CD Image Patch
Kronuz
Reply 3 of 9, by Kronuz
Okay, this is an step closer to a full unmount.
I've added a couple things to fix the bug that let unmounting cdrom drives between two other cdroms (breaking the chain of cd drives) this should no longer be a problem.
CD Images Unmount has become CD Unmount (full support) and it's quickly morphing to * Unmount 😀
Here's the fixed patch.
* Sorry the patch had a bug it and was corrupt, I've fixed it now (I think)
** I have added a PhysFS friendly version of the patch 😀
For this friendly version, apply the PhysFS first (you can still use this same patch without the PhysFS installed (if you don't want to use PhysFS, just skip the 'drive_physfs.cpp' file patch, ignoring 3 of 3 hunks and also ignore the 2 of 8 hunks FAILED message on file 'drives.h'.)
    dosbox-cdunmount-20060601d.diff
    18.14 KiB
    228 downloads
    CD Unmount (PhysFS compatible)
Kronuz
Reply 4 of 9, by ykhwong
I cannot mount cd-rom drive with limited support.
    18.69 KiB
Reply 5 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
does that make sense to mount a directory with -ioctl?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 8 of 9, by Kronuz
I now know where the problem is... I suppose it's a small design fault in MSCDEX_AddDrive() it returns an errorcode, the errorcode it's 0 if no error was found, and another number if something went wrong... or does it? well, almost.
0 = MSCDEX_SUCCESS
1 = MSCDEX_ERROR_MULTIPLE_CDROMS
2 = MSCDEX_ERROR_NOT_SUPPORTED
3 = MSCDEX_ERROR_PATH
4 = MSCDEX_TOO_MANY_DRIVES
5 = MSCDEX_LIMITED_SUPPORT
6 = MSCDEX_UNKNOWN_ERROR
Every single one of those non-zero codes is a "fatal error" making the mount to fail (and every one of them should destroy the half-created cdrom object) however, MSCDEX_LIMITED_SUPPORT isn't a fatal error, actually it's a success code (even when the "cdrom" has limited access, it succeeded to mount it.) This breaks the "0 means succeded" supposition I had. I think those error codes need to have a close look and better more consistent values; perhaps fatal errors could be negative integers, while success errors could be positive numbers and the 0... perhaps implementing a global common errorcode scheme with macros as SUCCEEDED() and FAILED() would be a good thing.
* Okay, I decided to post a temporary patch, this would make it easier for you 😀
    dosbox-cdunmount-20060613.diff
    18.42 KiB
    196 downloads
    CD Unmount with Fixed Limited Support Issue
Kronuz
