First post, by galbi
Hi friends, thanks for supporting Dosbox, it seem's to be what i was looking for.
I'm trying to run a simple MSDOS billing application (done in COBOL) under Linux, i had no problem in mounting directories and so on, but when run the program i got the error shown in the attachment[/img]
Can you tell me where to look for clues.
Thanks in advance.
(Sorry for my english)
Galbi. From Argentina
CPU: Celeron D
Mem: 256K
Linux: Slax KillBill
DOSBox vers: 0.63
Linux knoledge: A newbie 🙁
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Hello Galbi - welcome to VOGONS.
As a first step, I recommend that you download and install the lastest version of DOSBox: 0.65.
If you are lucky, that will solve your problem.
If not, come back, and tell us how you have configured DOSBox (look for a file called dosbox.conf in the directory where you installed DOSBox).
_________________
Reply 3 of 5, by eL_PuSHeR
Welcome, Galbi
I recommend using GIF or PNG image file formats for captured screens. JPEG is meant for photographic images.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 5, by Zup
Try using DOS32 instead of DOS4GW...
I'm selling some stuff!
Reply 5 of 5, by wd
Rank DOSBox Author
DOSBox Author
Using the 0.65 release should be enough, thus working in the
original (dos4gw) configuration.
