First post, by berbil
First-time poster here, but I've been lurking for a while! What might cause bad sectors on a hard drive to randomly appear and then subsequently move around? I understand what they are and why they occur, but I encountered a strange situation with two used drives that I recently purchased. Both sellers provided reports and screenshots showing that the drives were clean with zero bad sectors (log files still on the disks). After I received the drives, I repartitioned and formatted them. To my surprise, both drives now display bad sectors in the last 5% of the allocation area. They're 1995-era Western Digital Caviar drives.
I've since done a variety of scanning and "repairs" using WDDIAG, SpinRite, and regular old ScanDisk. The bad sectors seem to move around. An initial DOS format will usually flag some bad spots. Then, I'll run WDDIAG, which will find the bad sectors and indicate that the "maximum number of reallocations has been exceeded." When I run ScanDisk, about half of the bad sectors are miraculously gone. After that, an in-depth scan and repair using SpinRite will clear up another 25% or so. If redo the whole process from scratch, the overall statistics are the same, but the bad sectors are now in slightly different locations (but are still confined to the same 5% region at the end of the drive at the upper cylinders). The outcome is the same on two different computers with different IDE controllers and cabling.
I've been around this stuff since the very early '90s, so I'm no stranger to mechanical disks, but I've never seen this behavior before. (Admittedly, I have zero experience with the failure modes of 25-year-old hard drives.) I'm suspecting that the drives may have been damaged in shipping, with the usual bumps and jolts lodging some internal debris loose and affecting the edge of the platters. That might also explain the moving bad spots, if something were dragging across the disk. It's just strange that it would happen to two drives in the span of a week.
Has anyone seen this sort of problem before?
Reply 2 of 8, by berbil
Good thoughts, cyclone3d, but I've tried two different computers and different cabling. Different memory between the systems, too. (I coincidentally also ran MemTest86+ for several hours on the one system and it didn't find any memory errors.)
Reply 3 of 8, by derSammler
berbil wrote on 2020-04-24, 17:49:
Then, I'll run WDDIAG, which will find the bad sectors and indicate that the "maximum number of reallocations has been exceeded." When I run ScanDisk, about half of the bad sectors are miraculously gone. [...] If redo the whole process from scratch, the overall statistics are the same, but the bad sectors are now in slightly different locations
See, if you have more bad sectors than can be relocated, restarting the whole process will always cause different bad sectors to be relocated, until it can't relocate anymore again. The remaining bad sectors may appear, disappear, and reappear again, because they are normally not completely dead, but unreliable. Scandisk unfortunately does several tries before marking a sector as bad, which is nonsense, because if a sector fails even only once, it should never ever be used again. Anyway, trash the hard disks, they are done.
Reply 4 of 8, by PC Hoarder Patrol
Sadly an all too common problem with these old WD Caviar-series drives. I've a few of these with similar problems, where the bad sector size / location moves with every scan or reformat and if it's not that they suffer from the 'stiction' issue as well. I keep mine for nostalgia only but as @derSammler says, bin (or return).
Reply 5 of 8, by digger
I remember hearing or reading about computer viruses in the MS-DOS era that would mark the disk sectors in which they hid part of themselves as bad.
It might be an unlikely cause, but you might want to rule it out with a thorough scan, regardless.
Reply 6 of 8, by berbil
Aw, too bad. Thanks for the input and ideas, everyone.
That makes sense about the sector reallocations hitting their limit with each new scan. I've read that old sectors can sometimes be coaxed back into working order if you can perform multiple read/write operations at the specific location on the disk, but I suspect it'd only be a temporary solution if the platter magnetization is degraded due to age or physical damage.
I tried the virus scan, too. Didn't find anything, but it was a good idea nonetheless.
I'm using the Caviar drives for a period-correct PC build, so I guess the unreliability is par for the course after all of these years. I went through a ton of these drives back in the day as storage capacities seemed to expand without limit. I don't think they were very good drives even at the time, but I have a lot of fond memories!
Reply 7 of 8, by derSammler
You can try getting a WD Caviar 6.4 GB or later. I'm using two of these 6.4 GB ones and they are very reliable, unlike the older ones. Not a single bad sector so far and they have a huge amount of power-on hours.
Reply 8 of 8, by berbil
That's a good idea, derSammler. I just looked up a picture of those drives and I remember having a few of that newer style at one time. I suppose I could just create an 800 MB partition to match the mid-'90s vintage of the system I'm building. 😀
