First post, by Jackhead
i like to setup my midi device and joystick for the Kilrathi Saga.
Maybe im blind but is there no way to run a setup? Installer is windows, but how do i config my devices ?
I setup WC3 in dosbox with all the tweaks, but the windows version runs better, without glitches..
Is it possible to setup somehow? -i dont work.
regards
Chris
Dos 6.22: Asus VL/I-486SV2GX4 Rev 2.0 1Mb L2 - AMD A5x86 X5 ADZ 133MHz @160MHz - 64MB RAM - CT2230 - GUS ACE - MPU-401 AT - ET4000W32P
Win98SE: Asus P5K-WS - E8600 @ 4,5GHz - Strange God Voodoo 5 6000 PCI @ 66MHz PCI-X - 2GB DDR2 1066 - Audigy 2 ZS
Reply 1 of 3, by dr.zeissler
No Midi, just WAV/MP3 based on Midi , or am I wrong here?
Reply 2 of 3, by derSammler
It will use whatever you have configured in Windows (game controller and default MIDI device). The version of WC3 that comes with the Kilrathi Saga is a native Windows application. At least that's what I remember when I last installed it.
Reply 3 of 3, by Jackhead
ok thanks guys, than i switch to dosbox and take some glitches..
