First post, by dave343
I've wanted to build a system from around the 1994 era for a while, but I'm limited in the parts I have on hand and so I'm ooking for some advice. Games I'm looking to run will include everything from the original very early Sierra 1990 titles (Police Quest, Quest for Glory, Sam and Max etc...), up to and including games like Tex Murphy Under a Killing Moon, Sierra's Gabriel Knight Beast Within, Phantasmagoria... pretty much all those early 90's VGA/SVGA Adventure games, as well most of the FMV Games up to the 1995 year. 1995 tops.
I'm waiting on an ATX to AT adapter that I ordered, if it ever get's here, but outside of that here are the parts I have currently.
Intel 486 DX 33 & AMD 486 DX2 66 (Will most definitely use the AMD DX2)
Asus 486 SV2 ISA (*No VLB slots, this was the ISA only board of the VLB version)
8MB 30pin Ram (I think 60ns)
1GB CF-Card Trend x133 card
Cirrus Logic 5429 ISA 1MB
SB 16 (Mine has the Yamaha OP3 chip, although I also have a 2740)
Lucky Goldstar IDE/Floppy Controller card ISA 16bit
Nice Mid AT Case
EVGA 450w ATX Bronze, this thing will never break a sweat!
I will more than likely stick with Dos 5 & Windows 3.11.
So, obviously with the board not having VLB, I'm very limited with the graphics cards, mind you I think the 5429 I have was one of the fastest ISA cards anyways. I'm willing to invest around $200 CND or $150 USD into this system to keep it a 486, but I'm also looking to get a Mechanical PS2 keyboard since the PS2 keyboard I'm using is a PC Concepts really crappy to type on keyboard.
However....
All this being said, I have ALOT of Pentium 1 parts, and although this will let me "cheat", I really wanted to keep with a true 486 system. I could build the following...
Preface: I have most every Pentium CPU from the 75 to 233mmx, with the exception of the 120/133. I also have a K5 100, but that's just too recent as it was released in 1996.
* Intel Pentium 75 (THE slowest Pentium, released in 1994) Yes... I'm aware of the 60/66mhz egg fryer's that were the true original Pentium's 😁
* 8MB / 16MB EDO
* Asus TX97-E (1997)
* 1GB CF Card Trend x133
* S3 Trio64V2 DX 2mb PCI (1996/97)
* SB 2740 ISA
At a later day, maybe next month, I'm going to be building an ATX system around the 1999/2000 era, using either a Celeron 366, or Early Coppermine P3, 128mb, and Voodoo3 2000 AGP card. So for games after 1996ish, this will be my goto system for those. Will use Windows 98.
So I guess my question is, using the 486 spec's I listed, can I get away with running a majority of the FMV games from 1994/95 and keep this system with parts up to and including 1994. The AMD DX2 66 came out in September 1994, so I feel like this will be a good chip, and yes, it's the 5V version. There is 128kb cache, or 256kb, have to check again on the board. I've already removed the barrel battery from the board, and soldered on a 3x 1.2V Nicad replacement.
I really want to keep this as retro as possible, 1994. I know VLB was widly available and being used in 486 systems back then, however just looking on Ebay, I would blow right past my budget of $150usd just acquiring a 486 VLB board, and that's without yet purchasing a VLB based Video Card. So, the Cirrus Logic 5429 I have isn't ideal, but at least I know it's decent in terms of ISA performance.
Thoughts? Thanks in advance for any suggestions and advice.
Reply 1 of 48, by cyclone3d
What about a PCI / ISA 486 motherboard? I see a few currently on eBay for not that much. That way you have a much cheaper option for faster video cards as well.
I think part of the crazy prices right now are due to the whole pandemic thing going on right now.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 48, by Intel486dx33
It depends.
Do you want a period correct 486 computer
Or
Do you want the best game playback of modern DOS games and Multimedia ?
If you go with a 486 then this is a good build.
486dx2-66
256kb cache or more
16mb ram
410mb harddrive
Cirrus logic 5428 or 29 is good. 2mb
Or Tseng ET4000 2mb
Sound Blaster 16 with Yamaha OPL3
4x CDROM drive or faster
DOS/Win3x
If you want a Pentium then
Pentium 75 thru 233
32mb or 64mb of ram
512kb cache or more.
2mb PCI video card at least
Sound Blaster live 5.1 ( PCI ) or Sound Blaster 16 with Yamaha OPL3
4x CDROM or faster
540mb hard drive or larger.
Win95 or DOS
Reply 3 of 48, by BinaryDemon
I'd ask if anyone here played some of those FMV games with an ISA card. I would imagine your point and click adventure games would be fine.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 4 of 48, by dave343
Intel486dx33 wrote on 2020-04-27, 16:53:
It depends. Do you want a period correct 486 computer Or Do you want the best game playback of modern DOS games and Multimedia ? […]
It depends.
Or
I'd like to stay period correct for 1993/1994. I have a complete Pentium 100 build right now, and while I could save myself a ton of time, where is the fun in that 😁
When you say 5429 in your list, which is what I have, are you referring to VLB or the ISA?
For 486 Systems in 1994, I don't remember knowing anyone who had a DX2, let alone even a Pentium. Most of my friends had late 386, or early 486 class systems in 1993/94 and it wasn't until 1996 that I even knew a kid that got a Pentium. Tex Murphy Under a Killing Moon, came out in 1994, and although it's FMV, how many people actually had 486/DX2 66 systems then, I can't imagine many until the cost came down in 95. I guess my primary concern is the ISA Bus, but guess I'll build it and find out 😀
cyclone3d wrote on 2020-04-27, 16:02:
I've been checking eBay, but they are still fairly expensive, more that I was looking to pay. RE-PC in Seattle had a special with a 486/PCI board, AMD 5x86/133 chip, and 16mb ram for $100 but I skipped it, guess I'll have to wait until they re-open to see if he still has it.
I think I'll just build the system with the parts I have, give the games a try. I'm not looking to run anything past 1995 or Gabriel Knight 2, but I think even the Cirrus Logic 5429 I have, as good of a ISA card as it was might not be up to the task. I'll report back with my findings 😀
Reply 5 of 48, by CoffeeOne
dave343 wrote on 2020-04-27, 18:50:
I'd like to stay period correct for 1993/1994. I have a complete Pentium 100 build right now, and while I could save myself a to […]
It depends.
Or
In 1994 Intel released the famous 486 DX4/100!
It was very expensive when it came out, but now it would not be a problem anymore 😁
when you say 1993 then it would be 486 DX/66 or Pentium 60/66 (when you want high end, but not so easy to get now)
Reply 6 of 48, by dave343
CoffeeOne wrote on 2020-04-27, 20:04:
Period correct to me isn't what was necessarily available due to release date, but what was actually being used in a given year by the majority of people, and more so what was the affordable norm!
Reply 7 of 48, by dave343
I received my ATX to AT adapter cable today... finally, thank you Canada Post 😁 (just took a month) But I’m curious about it’s 3 AT plugs, the ATX splits into 3 Cables for the AT board... but what’s with the Half Orange / Half Black cable? Don’t remember seeing that before, unless it’s just been a very long time.
68.3 KiB
Reply 10 of 48, by dave343
red-ray wrote on 2020-04-27, 23:55:
dave343 wrote on 2020-04-27, 23:45:
That is for boards such as the ASUS PCI/I-P54NP4 that need +3.3 volts.
Ok thanks.
Reply 11 of 48, by dave343
Interesting review I found on Under a Killing Moon, written back in 1995... who knew blogs existed 😁 But it answers my question somewhat, since I haven’t tried it myself. Author mentions a few interesting key points:
“It comes on four CD's and seemingly delights in telling you that your video card is not fast enough and your 486DX2 66 with 8 Mb RAM is under-powered!”
“Though the game designers recommend 16 Mb RAM don't panic. I played it with 8 and a slow 1Mb video card. It was fine. But this doesn't mean you can relax if all you have is 8 Mb RAM - it's not going to be very long at all before nearly every game is screaming out for you to upgrade.”
Review link here -> http://www.metzomagic.com/showArticle.php?index=66
Reply 13 of 48, by darry
dave343 wrote on 2020-04-28, 04:34:
Interesting review I found on Under a Killing Moon, written back in 1995... who knew blogs existed :D But it answers my question […]
I played it on an IBM PS ValuePoint 6384 F20 (486 SX 25 , ISA Tseng ET4000, 5MB of RAM ) and a 1/2 speed or so Magnavox CDD-461 . It was painful, but I enjoyed playing it nonetheless .
Reply 14 of 48, by chinny22
95 We got our first PC DX2/66 8MB Ram, Onboard VLB Mach64 1MB , SB16, 2x CD-ROM
It was a "multimedia PC" so your looking at about the right hardware. It came with Return to Zork which is FMV and played ok from memory, playing off the CD would have been the bottleneck. If you can no-cd the games in your list and play them off the HDD you'll get a very nice performance boost I'd think.
I wouldn't get that upset about lack of VLB, It's just now people that want 486's are representing an era. 486's are pretty pointless as a gaming PC (too fast for early games, too slow for late dos games)
The fact is you want a 486 and thats all that matters. Build it, enjoy it , and if a game doesn't run well enough then you already have the Pentiums.
Reply 15 of 48, by dave343
kolderman wrote on 2020-04-28, 04:36:
Blogs didn't exist. They were called Home Pages 😁
Yeah, as a teen throughout the entire 90’s I definitely remember haha, I was just kidding 😁
Reply 16 of 48, by dionb
dave343 wrote on 2020-04-27, 20:17:
In that case, go with your ISA-only 486 board as it's far more representative of what most people had then - albeit still faster than average. I had to make do with my mother's i386-16 from 1988 and my best friend had a 286-12 bought in 1990.
Reply 17 of 48, by dave343
chinny22 wrote on 2020-04-28, 09:12:
95 We got our first PC DX2/66 8MB Ram, Onboard VLB Mach64 1MB , SB16, 2x CD-ROM It was a "multimedia PC" so your looking at abou […]
Yeah, thanks.
What you got in 1995 sounds like a norm heh, because even in 1995 (when Pentium’s where widely available) I bet your system still cost over $1-1.5k .
As for the 486 being a gaming PC, I would agree they aren’t the best, because you still can’t play those very early dos games, but you’re also limited when it comes to anything in or past 1995. That’s why I’ve always felt the best system is a nice Pentium 75 / 100. Let’s you enjoy all those late Dos games, Quake, Doom, all the FMV games as they were meant to be enjoyed, and you can slow down the Pentium to run those very early 90’s dos games that were speed sensitive.
I never did own a 486 in the 90’s, which is why I like messing around with them now. In 1992 my Dad bought AMD 386/40 which also had a Cyrix math-co and 8mb ram. I don’t even remember us having a sound card. Then it wasn’t until April 1997 that he bought a NEC Ready 9712, or 9716 with a 166MMX, with 32mb ram. So, that period between 92 and 1997 was painful.... haha. I only remember being able to play Sierra adventure games on that 386, forget about any FMV games on the 386 😀
We also didn’t get a modem and the internet until 1997 in the NEC PC, so I missed the entire BBS era 🙁
Reply 18 of 48, by Anonymous Coward
A friend of mine had an ISA 386DX-40 with 128kb cache and 8mb RAM. He put the Creative 2X SB16 discovery kit into that PC, and believe it or not he did play FMV games on it in 1994. I specifically remember the 7th Guest and "The Magic Death" being tolerable. I don't know if Inca II counts as FMV, but I remember that one on the 386 as well. The 386DX-40 was actually pretty good value during the 486 era, and not nearly as painful as the last poster remembers. It was only during the 1995-97 period that 386s and 486s became intolerable. Once Windows 95 came out it was Pentium or nothing.
So I think the hardware specs listed by the original poster are pretty decent for what he wants to play. 1995 might be pushing it for some titles though. FMV is probably fine at 640x480x256 provided the video is not full screen. But if you want to play "3D" games or software that does high bandwidth video then you'll want VLB...but at that point you'd probably want a Pentium anyway.
Reply 19 of 48, by dave343
And so the build begins...
1.21 MiB
1.58 MiB
