Duke 3D with VDMS
First post, by Unregistered
Hey all,
When running VDMSound with Duke 3D, the game crashes just before it plays ANY sound, first thing, this happened during the setup program, as soon as it tries to play the sound by the "Test Sound" or the "Test Music" features, the program jsut freezes.
If I just save the settings and exit, and then try to run the DUKE3D.exe, it goes through the usual loading proceedure, then right before it goes to play the sound for the little start up sequence, it shows the first frame of animation, then it freezes too.
Any ideas?
OS: Win 2k
CPU: AMD K6/2 500
MEM: 192 MB
Need more?
Email me...
moc_leader@iprimus.com.au
Replying to this message?
Email me again 😀
Reply 1 of 32, by vladr
Yes, Duke does not like Windows when sound is enabled. CLI2NOP (see Deep Thought forum and/or the alt.games.duke FAQ on http://groups.google.com/ ) may help to a certain extent. Or upgrade to WIndows XP and get VDMSound "Update 1". Or look for a Windows/Java/etc. rewrite of Duke.
V.
Reply 2 of 32, by Nicht Sehr Gut
Like Vlad said CLI2Nop (then with VDMSound afterwards) is about your only immediate option.
The best bet is a dual-boot with DOS or a Win9x OS.
Even if you get it running in Win2K or XP, you may also have to deal with VESA 2.0 issues. If so, you may also need to use NOLFB.COM (available in the Magrathea/Deep Thought forum under "Ken Silverman releases VESA Fix for NT/2K/XP".
Reply 3 of 32, by Unregistered
I have windows XP and the latest VDM sound, i tried Cli2Nop on Blood 1 , it crashed on first sound play (happens to be before i reach main menu)
Same with Duke and Shadow Warrior, it seems any game on the engine will fail.
Help!
Reply 4 of 32, by DosFreak
Did you install VDMSound Update 1?
That's it. I'm gonna upload my VDMSound directory with VDMSOUND 2.04/Updated1/& Launchpad to the board.
Instalation will be easy. Instead the VDMSound 2.04 MSI, unzip the .zip into your VDMSound directory. Run install.bat to install launchpad.
Make your games work offline
Reply 7 of 32, by Dijeeh
Im the Unreged guy with XP, just regged for you 😀
I now have a new problem, trying to run RedNeck Rampage.
I get the error "DPMI_Map Physical to Linear Failed"
or close to it.
This has happened on a few other games util i set it to VGA 300x200 (duke and Shadow warrior)
RedNeck Rampage only allows VESA 🙁
I recall i managed to get VESA working before.
Hows it done?
Reply 9 of 32, by Dijeeh
Thanks will try it out now!
Reply 10 of 32, by Dijeeh
Ok, i just run the program like it says on the website, and i still get the error.
I have a Geforce2
Reply 11 of 32, by Dijeeh
OK! i got the game to run
It only works using the command prompt though, and thus VDM settings dont come into play when rr1.exe is run.
Thus, i get IRQ conflict error if sound is on
If i turn sound off in setup.exe i can load into the game just fine.
But having no sound is quite useless
Erm.. how do i run a game from the command prompt, with it keepings it VDM settings?
Reply 13 of 32, by Unregistered
Nevermind it works
Reply 14 of 32, by Stiletto
I'm confused. Was that Dijeeh (just not logged in) or the original poster, moc_leader, that posted "Nevermind. It works."
...I don't want to think about Windows 2000 or XP running on a K6/2 500. *shudder* SLOW...
do the Fandango!" - Queen
Stiletto
Reply 15 of 32, by Dijeeh
It was me, these forums are really a pain in the ass for me, it cant remember my login, so i have to login for each post.
Only forum thats ever done it 😒
It also refuses to give me access to my control pannel. im noth autherized!
Reply 16 of 32, by [vEX]
I'm running XP on a K6-2 400MHz and it aint slow, runs like a breeze (I'm pretty sure my 448MB SDRAM helps it).
Antec P182B | Asus P8Z77-V PRO | Intel i5 3570k | 16GB DDR3 | 4TB HDD | Pioneer BDR-207D | Asus Xonar DX | Altec Lansing CS21 | Eizo EV2736W-BK | Arch Linux (64-bit/x86_64)
Reply 17 of 32, by Snover
Dijeeh,
Make sure you're accepting cookies from www.vogons.org as well as .zetafleet.com.
Yes, it’s my fault.
Reply 19 of 32, by Dijeeh
Sorry the above post was me, damn forums 🙁
