HWiNFO support of vintage hardware
Reply 320 of 683, by Mumak
I was looking at detection of PS/2 mouse.. It's very simple, but.. that method is causing a reset on my system.. any check for legacy HW that I add is causing an issue somewhere...
The check for not listing removed hardware that I implemented a while ago didn't work well and it was causing skipping of present cards too. So I removed it and currently don't know how to skip this properly.
Reply 321 of 683, by phantom_pl
I downloaded latest version (6.1.0), and retested a FIC board fror CPU sped issue.
I have also dug yet another old 486 board (Shuttle HOT-409) and ran some tests with it.
Results are:
FIC 486-GVT-2
- Still have an issue displaying incorrect CPU speed on the screen (report is however OK.)
SHUTTLE HOT-409
- This is an early VL board with 30-pin simms, LIF socket for CPU, and no voltage regulator for fastter CPUs. It has installed latest unofficial BIOS with support for >504MB drives (I have used a Transcend TS2GIFD25 – a 2GB IDE SSD during tests). He board doesn’t like more than 1 VLB card being used. If used with 2 cards, system refuses to load OS or crashes. Loose timings and adding waitstates doesn’t help, and I have used VLB graphic card and ISA IDE/IO card for tests with exception of no.9 (vl combo card) and no.10 (2 vl cards, crashed soon after generating the raport). It came to my mind (after the tests ☹ ) that maybe slowing the clock to 25 MHz would help? The board doesn’t also like 40 MHz bus – UMC CPU crashed shortly after report was made, and Cyrix DX40 refused to even load DOS, so it was run at 33 MHZ with no problem.
- Generally HWiNFO works ok. And recognizes correctly hardware being used, with the exception of 100MHz and 133MHz chips, in which cases CPU frequency is displayed and reported incorrectly. A 100 MHz CPU was able do display&report correctly if Auto Confi function in BIOS was Enabled, but alas, system was not stable then ☹ .
I guess, that BIOS couldn’t recognize that fast CPU and set incorrect timings.
With timings set manually system works stable, but CPU speed is reported wrong. (CHKCPU however detests it correctly).
Logfiles are attached.
Regards
    610reports.zip
    37.03 KiB
    56 downloads
Reply 322 of 683, by Mumak
phantom_pl wrote on 2020-04-29, 09:56:
I downloaded latest version (6.1.0), and retested a FIC board fror CPU sped issue. I have also dug yet another old 486 board (Sh […]
Results are:
FIC 486-GVT-2
SHUTTLE HOT-409
Regards
Thanks for the extensive report !
I see that there are a few minor things I can improve, but I still have no idea what's causing the reduced clock speeds for >100 MHz reported. What happens if you close the Mainboard info screen and open again a few times? Will it still show the low clock?
Also a question regarding #10: this one had an ALG2228 card, what's its exact name, some SPEA ?
Reply 323 of 683, by phantom_pl
Mumak wrote on 2020-04-29, 11:48:
Still no changes. Every time the clock shown is too low
Exactly, SPEA V7 Vega Plus
Reply 324 of 683, by Mumak
phantom_pl wrote on 2020-04-29, 12:57:
This is totally weird.
HWiNFO measures the execution time of a certain instruction set, so if it reports wrong there can be 2 reasons only: either the clock has really changed or something messed-up with the timers.
And if you exit HWiNFO right after it reporting low clock and launch CHECKIT does that report correct clock?
Thanks, will add reporting of the card.
Reply 325 of 683, by appiah4
I didn't know about this thread until today.. I will submit a report from the Win32 version using my retro daily driver (a cookie cutter Pentium MMX build) later today. I will also try the DOS version. Not sure if that actually crates a debug report but if it does I will try that as well.
Reply 326 of 683, by Mumak
appiah4 wrote on 2020-04-29, 13:18:
Thanks in advance. The DOS version doesn't create a debug output.
Reply 327 of 683, by phantom_pl
Mumak wrote on 2020-04-29, 13:03:
I agree, that's weird, and most weird is correct clock in the report, and too low on the screen.
CHECKIT - ??? I have never used this tool, unless you mean CHKCPU .
I use CHKCPU 1.25 as a reference tool , and it shows correct clock
I took a picture of screen with CHKCPU running on 486dx4100, but I don't remember whether it is FIC or Shuttle board (but it looks the same)
    260.81 KiB
Reply 329 of 683, by phantom_pl
Mumak wrote on 2020-04-29, 13:39:
Sorry, I meant CHKCPU 😀 Would be interesting to know what it reports right after HWiNFO reporting low clock. Just to prove whether HWiNFO does perhaps mess-up something with the clock.
I have already checked it, and I'm sorry, CHKCPU is always correct 🙁
Reply 330 of 683, by Mumak
phantom_pl wrote on 2020-04-29, 14:19:
Crazy... looks like nothing is impossible in this vintage world 😁
Scratching my head.... is the clock wrong also if you disable Reset Methods 1-3 ?
Reply 332 of 683, by phantom_pl
Mumak wrote on 2020-04-29, 15:02:
Nothing, but one....
A system capable of perfectly running all DOS software, with proper speed, and ideal sound 😁
Reply 333 of 683, by Mumak
phantom_pl wrote on 2020-04-29, 15:44:
Please try with this build if it's any different:
HWINF610.ZIP
992.24 KiB
53 downloads
Reply 335 of 683, by feipoa
Tested DRx2-66 at 66 MHz using the ALi PANDA board in Win95c. report and debug attached.
The CPU name looks wrong in the heading field. Shows up as: Cyrix Cx486DRxý-101.
    DRx2-66.rar
    5.22 KiB
    68 downloads
Reply 336 of 683, by BSA Starfire
Report file from my Cyrix MII, only thing that is obviously wrong is the sound card, it has a ESS 1869 on board with drivers loaded and working but isn't detected.
A few other things I notice is that is says max level 2 cache is 512k but shows the 1MB the motherboard contains. The CPU voltage shows as 3.3 v on the CPU tab, but the correct 2.9v on the summary and mainboard tabs, not sure if I'm not just reading this wrong though and that is is I/O voltage shown on that tab?
    Z7S8O2.zip
    10.73 KiB
    53 downloads
Reply 337 of 683, by Mumak
BSA Starfire wrote on 2020-05-03, 13:17:
Thanks for the report. The max cache size (512K) and 3.3 V come from BIOS, which is responsible for providing accurate information, but it's often not the case.
Could you please try this build if it recognizes the ESS card: www.hwinfo.com/beta/hwi32_625_4146.zip
Reply 338 of 683, by BSA Starfire
Yep, that's fixed it 😀
Z7S8O2.zip
11.07 KiB
52 downloads
Reply 339 of 683, by phantom_pl
In my case nothing is fixed 🙁
Both boards (FIC 486-GVT-2 and Shuttle HOT-409) report and display wrong CPU clock (FIC is almost there in the report, but not on the display).
Report + HWiNFO printscreens + CHKCPU before&after screens are attached.
    Report_0405.zip
    1.21 MiB
    72 downloads
