First post, by ih8registrations
graphics optimizations:
bitumove: 128 bit blit
modeoperation: skips calculation if same as last pixel (this speeds up this function 3x in wolf3d for example)
writehandler: inlining of the first invocation
http://sourceforge.net/tracker/index.php?func … 551&atid=467234
autocycle:
no more skips or lag from cycle transitions(prior, wasn't usable on my system)
displays current cycles(instead of "auto") & framerate once a second
for cycles set to a specific count, cycles auto adjust up to that count.
use for programs that need a specfic cycle setting so as to not run too fast but still adjusts cycles downward when cpu load is exceeded or to reduce cpu load. Set large enough it essentially mimics autocycle.
edit: added autocycle patch.
edit: grab graphicsopt2.diff to avoid issue discussed in the thread. But if you want to check out the buggy changes, knock yourself out with graphicsopt.diff;)
edit: cleaned up autocycle.diff, it had a part of the graphicsopt changes ini it. attached is autocycledlean.diff
    autocycleclean.diff
    8.07 KiB
    240 downloads
    autocycle.diff
    10.39 KiB
    235 downloads
    graphicsopt.diff
    12.82 KiB
    247 downloads
Reply 1 of 44, by ih8registrations
Executable for those who want a look-see without compiling.
    dosbox.rar
    2.87 MiB
    256 downloads
Reply 3 of 44, by Spooon69
I downloaded this for the autocycle feature (max limit and display) because of the sound problems in the official version. This patch definitely helps as long as you set the limit correctly. Thanks and I hope this gets integrated into official!
Reply 5 of 44, by ih8registrations
If you're using the exe, it may be some other changes that are in the build I'm working on that's not in the patch. But perhaps bitumove.
Reply 7 of 44, by ih8registrations
Actually those changes did sneak into the patch, and are the cause of the bug. If you replace render_loops.h with that from cvs, you should be good to go.
I've attached a diff sans changes to render_loops.h
That said, I did find one game that has trouble with the modeop optimization; tornado. More bug squashing to do.
    graphicsopt2.diff
    11.09 KiB
    213 downloads
Reply 12 of 44, by ih8registrations
I figured it out; needed to include vga.latch.d in the dirty check.
Fixed tornado. Check it against Prehistorik 2 and bumpy.
    graphicsopt3.diff
    12.21 KiB
    221 downloads
Reply 13 of 44, by wd
Rank DOSBox Author
DOSBox Author
Any big games that you tested the graphicsopt with? As most of those
(like Quake) use linear access to the graphics memory (mode13/vesa),
i didn't notice any speed gain. Suppose mode12-like games would
benefit from it, or tweaked-mode?
Reply 14 of 44, by ih8registrations
If you look at vga_memory, you'll notice modeoperation is only used by unchained vga(aka tweaked vga at mobygames), and chained/unchained ega modes. Even though wolf3d isn't one of the big games, it runs like a dog and modeoperation is one of its big-o calls, which is what led me to optimizing it. The most efficient is LFB, which does straight array accesses. I think games like quake use the map handler if not LFB. Just to reiterate, it's a 3x speed up just for that function(as shown by gprof), for wolf3d. For other games it will vary. Feh, I still get lost with c++'s inheritance so others may be using the writehandlers that call modeoperation.
Reply 15 of 44, by SysGOD
ive tested some SVGA games (Z, Quarantine 2, Exhumed, Hioctane, Rise of the Robots...) with your optimizations for some days now.
Z runs like a dream on my system, no sound stuttering with dynamic core above 60000 cycles anymore. also hioctane seems to benefit from the optimizations.
but quarantine 2 is unplayable. gamespeed goes from high to very slow all the time in hires. screen tearing and sound stuttering also. ive tryed many different settings without any better results.
Reply 16 of 44, by ykhwong
SysGOD, if I am right, you applied svga patch, right?
Did you modify some lines in graphicsopt patch against SVGA patch?
ih8registrations, the third patch made the screen of prehistorik 2 much worse. There's still a bug in bumpy.
Reply 17 of 44, by SysGOD
no iam only using the precompiled dosbox.exe for now.
dont have any compilers on my system yet...
maybe ih8registrations has some other things changed in his .exe, i dont know.
