First post, by Sev80
I'm trying to use the graphical terminal program for Land of Devastation (gterm.exe) so I can play said bbs door game using the graphical terminal. This uses a modem connection to a bbs.
The only way I've gotten gterm to work correctly is if I use the serial1=nullmodem server:(bbsname.com) telnet setting in dosbox.conf. And when I use this method, it works, but it is EXTREMELY slow, like 2400 baud slow, maybe even 1200 baud slow, which makes gameplay tough. Is there any settings I can set to speed up how null modem emulation connects?
I see there's an old thread from 2010 saying the serial stack in dosbox needs a rewrite. Did that ever happen? Is there something I'm missing? Help!
Puzzled - DOSBox Emulated Serial Modem Very Slow (2400 baud-ish)
Thanks,
