First post, by sixersfan105
So I recently snagged one of my family's old computers from my parents' garage: a Compaq Presario 5032. I know, I know, nothing special, throw it away, etc. But the nostalgia factor is real and I want to get it up and running. It's got a 300 MHz Pentium II and I upgraded the RAM the other day from 64MB to 256MB (the max permitted).
Only issue is that the hard drive, a 5.25" IDE Bigfoot TX 8GB is dead. Well, not fully "dead," per se, as the drive itself flashes and hums but for sure isn't spinning up appropriately. So for all intents and purposes, it's dead, and it does not get recognized at all in BIOS or otherwise.
I did a little research and it seems like these are my options, in no particular order:
1) Obviously I could replace it with another 5.25" drive from that era, or a 3.25" from that era or a little newer, as it's a regular IDE/PATA interface that I'm working with. I probably wouldn't want to go too big from a storage standpoint out of fear of the computer being unable to recognize a larger capacity. Even if I get a brand-new old stock drive, with all of its moving parts, it would be prone to failures.
2) IDE to CF adapter. The solid state aspect is attractive, though a part of me feels like incorporating newer tech into this 1998 machine is cheating just a little bit. That said, seems like it could be a good option, so long as I get an "industrial" or similar CF card that is confirmed to be bootable.
3) IDE SSD - haven't come across much info on these but they seem to exist.
4) Microdrive (using an IDE to CF adapter) - read somewhere that microdrives last longer than regular CF cards, so that could be a decent option?
Any insight into the pros and cons of these - and potentially other - options would be greatly appreciated. Thank you!
