Reply 33721 of 52819, by PC Hoarder Patrol
Yes. There's always a few on the Bay but prices are normally high as EISA VGA was probably the least used element of the bus. I got this privately as part of a bundle of PCI cards.
Reply 33722 of 52819, by kolderman
What do you do when you have too many motherboards already? Buy another of course.
I have a bit of a weird fetish for mATX s370 boards with ISA that I can use to build compact DOS/Win98 gaming machines with a Via C3 cpu. This one will be perfect for my pci Voodoo Banshee and maybe a SB live + Audiodrive.
PS: i just noticed this board has an unsoldered SBLink header as well.
PS2: It also comes with integrated "ESS Solo-1 PCI Audio controller" -- I wonder if that is connected internally to PC/PCI for DOS compatibility. Will be fun to try out. https://www.anandtech.com/show/286
Reply 33723 of 52819, by Joseph_Joestar
A friend gave me his old GeForce 4 MX440 yesterday, and I have to say, I'm pretty impressed with this little card.
PROs:
  • Passive cooling (I like my systems to be as quiet as possible)
  • Performance on par with a GeForce 2 GTS, maybe even the Ultra
  • Supports fog table and palletted textures (this matters for early Win9x games)
  • Can be used with older nvidia driver versions like 40.72
  • Using FASTVID, it can reach 70+ FPS in Quake 1 under pure DOS while running in software mode at 640x480
  • Good DOS compatibility
CONs
  • No DirectX 8.1 support (this doesn't matter for games released before 2001)
  • A bit slow in higher resolutions like 1280x1024, but this depends on the game
    Overall, I think this is a pretty decent card for Win9x gaming. Despite being labeled as a GeForce 4, it's actually much closer to a GeForce 2 in terms of features, but with higher core and memory speeds for a bit of extra performance. It also seems to be a lot cheaper than a GeForce 2 GTS on eBay and such.
Reply 33724 of 52819, by imi
kolderman wrote on 2020-05-03, 07:57:
that's the spirit!
PC Hoarder Patrol wrote on 2020-05-03, 02:01:
(After a bit of an issue with the courier) my Compaq QVision 1280/E finally showed up - from the box labelling, seems to have been an unused spare.
oh, I think I have one of these, I got it rather cheap on ebay and only bought it cause... EISA VGA ^^
Reply 33725 of 52819, by imi
this is the card I got, it's slightly different.
is there an easy way to tell if this is EISA or OPTiLB since it was apparently available in both?
the pin arrangement seems to be the same as yours... so I guess EISA?
edit: mine seems to be a "Qvision 1024/E" I guess 4/8 is just the amount of memory chips? ^^
though if I look for "1024/E" those seem to have a different graphics chip... hard to find definitive info.
472.91 KiB
Reply 33726 of 52819, by CoffeeOne
imi wrote on 2020-05-03, 16:01:
this is the card I got, it's slightly different. is there an easy way to tell if this is EISA or OPTiLB since it was apparently […]
Yes, that's the 1024/E, I have the exact same card in my Prosignia Server. There seem to be 2 variants of the 1024/E
1280/E is close to impossible to find. I wonder if the the 1280 also has VRAM or is it just DRAM?
Reply 33727 of 52819, by imi
if I search for "Compaq 1024/E" I mainly find references to this card with a different graphics chip: http://vgamuseum.info/index.php/help-identify … 04-qvision-1024
while mine also has the Motorola SC02SH007DK04, they differ in amount of memory and different RAMDAC though.
e: yes, compared to the 1280
Reply 33728 of 52819, by CoffeeOne
imi wrote on 2020-05-03, 17:05:
They don't differ in amount of memory, all 1024/E have 1 MB VRAM as far as I know.
Reply 33729 of 52819, by CoffeeOne
CoffeeOne wrote on 2020-05-03, 18:08:
Ah sorry, you compare the 1024 to the 1280 (?)
Reply 33730 of 52819, by PC Hoarder Patrol
Yours (002930-001) is the 1024/E with the 2nd generation V32 controller
73.79 KiB
57.02 KiB
Although mine came with an unopened pack of support disks, I'll hunt down the latest SoftPAQs online just in case.
* the 1280/E is 2MB
Reply 33731 of 52819, by CoffeeOne
PC Hoarder Patrol wrote on 2020-05-03, 18:21:
Yours (002930-001) is the 1024/E with the 2nd generation V32 controller […]
* the 1280/E is 2MB
Is the second generation 1024/E upgradable to 2 MB?
Do you know it?
I wonder for what these 4 connectors are(?)
Reply 33732 of 52819, by imi
ah! thank you :3
I certainly think it's upgradable, wouldn't know what else the connectors would be for, but good luck ever finding an upgrade module ^^
Reply 33733 of 52819, by PC Hoarder Patrol
These suggest a 1024 with 2MB (so I assume by a 1MB upgrade module) but don't quote a part number
https://ulihansen.kicks-ass.net/aero/software … ers/display.txt
https://pdos.csail.mit.edu/6.828/2008/reading … adoc/COMPAQ.TXT
Reply 33734 of 52819, by Swiego
The QVision/1024i controllers only included 512kb onboard with 512kb expansions... never seen a 2MB option for the onboard solutions. Ditto (not seeing a 2MB) option for 1024/e.
I have a computer with a QVision/1280i which has 1MB onboard but have not see the 1MB expansion. I’d love to have one. A QVision/1280e board is super cool!
Reply 33735 of 52819, by imi
got this one a few days ago, my third Dolch Pac computer :3
first one is a Dolch Pac 64 that is missing a few parts
second one basically just the shell of a Dolch Pac 586.
and now this nice Dolch Pac 61 which is still in good original condition :3 (apart from the one missing rubber foot on the keyboard)
and this one finally has an ISO DE keyboard ^^
I'm planning to build a nice portable retro gaming machine in the empty shell probaby since I don't want to tear the original ones apart.
I didn't wanna take it apart fully right now I just quickly opened it to see if it indeed has this really nice VLB/EISA combo motherboard inside (and no leaking battery), someone did a video about it: https://www.youtube.com/watch?v=P-tjq7WnFKs
and sure enough it does :3
114.21 KiB
180.99 KiB
297.47 KiB
Reply 33736 of 52819, by Horun
imi wrote on 2020-05-03, 23:29:
got this one a few days ago, my third Dolch Pac computer :3 first one is a Dolch Pac 64 that is missing a few parts second one b […]
Nice looking portable ! Does it have the original 486DX2-66 ? Read that is what the PAC 61's came with.
Reply 33737 of 52819, by appiah4
Isn't that the semi-portable High Treason made a video about not long ago and absolutely shat on?
Reply 33738 of 52819, by darry
appiah4 wrote on 2020-05-04, 05:22:
They were called luggables at the time . Got a link to that video ?
